Question about Frigidaire 5000-BTU Window Room Air Conditioner LRA050XT7
I have a window fridgidaire ac its stuck on timer can't get it off it how can I fix this
    New Friend:
  • 24 Answers
Unplug machine for 30 minutes and try again. If that fails replace board.
Posted on Jul 31, 2013
My fridgidaire dryer (gas) stops functioning throughout a timed cycle - I then reset the dryer timer and it doesn't want to operate again. Other than calling a tech to come fix the dryer, what t
Probably the motor behind the knob. I replaced mine in a Kenmore recently. No big deal for someone with average skills. Go to washer/dryer forums. Lots of them. This will have a ton of solutions. Try YouTube
Aug 06, 2013 | Dryers
Fridgidaire/Electrolux dishwasher stuck knob
It definately sounds as though the motor in the timer assembly is dying, or the gears in the assembly are wearing down to the point that the gears can't turn the way they're supposed to. Replace the timer.
Apr 17, 2012 | Frigidaire Dishwashers
Fridgidaire Error 68 (model No. LE02152EEO) and constant beeping!
this fault code means there is a stuck key on the control board.you need to disassemble the display panel and free up the stuck key if this does not work then the display panel and or control board need to be replaced
Sep 02, 2009 | Frigidaire AEQ6000ES Electric Dryer
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
Honeywell humidistat stuck
what i would do is make sure tha the hole for the wires that go to the humidistat is completely closed and that you are sensing the true humidity for the space also have the tech wire the so that the heat comes on instead of the ac for the de-hiumidification process.
Feb 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Fridgidaire 7 cycle - older model top loading washing machine wont drain
could be a stuck gear box. motor trying to turn it on the reverse rotation for spinning. it could be the motor that hums. or the belt could just be loose.
inspect the belt and see if it is loose and adjust it if necessary.
tnx 4 using fixya,
drcool
Oct 17, 2008 | Frigidaire CWS3600AS Top Load Washer
Fridgidaire ac window unit
More than likely this unit could be fixed reasonably. It sounds from your explanation like a bad connection inside the control panel of your unit. Could possibly be what is called a cold soldered joint.
Jul 18, 2008 | Frigidaire FAC126P1 wall/window Air...
Frigidaire 5000-BTU Window Room Air Conditioner LRA050XT7 Logo
377 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
