Question about Native Union Audio Players & Recorders
The Native Union POP Phone Handset comes with a cord terminated with aTRRS (3.5mm) male connector. My computer memory unit has a pink (mike) and a green (speaker) port to connect the POP Handset (or a regular headset with mike). How can I get an internal wiring diagram of the POP so as to know how to build an adapter to split out from the TRRS connector and connect into the computer memory unit. I have the female side od the TRRS as well as the 2 TRS connectors for the computer side.
  • 11 Answers
SOURCE: PTC relay on compressor
Try to find the "secret" wiring diagram.  Almost all refrigerators have a hidden paper wiring diagram.  It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan.  While you're in there, it's a good practice to clean the coils.
Posted on Oct 23, 2007
kleeper
  • 87 Answers
SOURCE: rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
Posted on Oct 24, 2008
  • 12 Answers
SOURCE: No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Posted on Apr 26, 2010
Testimonial: "Super info you've given...Thanks. Was going to replace it, but your suggestion is even better. Do you have to remove the switch to remove the casing?"
SOURCE: I need a circuit diagram for My Logitech Z-640 Computer Speakers
i have 2.1 channel speaker set it was not working what is the solution
Posted on Mar 08, 2011
pctech1
  • 1940 Answers
SOURCE: I have a cub cadet
Here are all of the Cub Cadet Wiring Diagrams from Cub Cadets website: http://www.cubfaq.com/wiringdiagrams.html
From your description, this almost matches the Original Cub Cadet wiring, but there are a few differences. Here is the wiring diagram: http://www.cubfaq.com/wiringdiagrams/original.jpg
The Cub Cadet 1200 and 1250 have the same wiring diagrams, but they are different from what you described. Here is the wiring diagram: http://www.cubfaq.com/wiringdiagrams/1200.jpg
I also found the Cub Cadet 125 to be somewhat similar to your description. Here it is: http://www.cubfaq.com/wiringdiagrams/125.jpg
Posted on Apr 12, 2011
Backup photos in photo frame internal memory.
There is usually some sort of "umbilical" cord that you connect between the Digital Frame unit and your computer. Should terminate in a usb male connector to plug into your computer for downloading and backing up images.
Jun 19, 2016 | PANDIGITAL 7" Digital Photo Frame With...
I have an old Denon stereo receiver DRA - 565 RD. Do you know how I can connect my iPhone to the receiver to play music from my iPhone?
You need a 3,5mm male stereo connector to RCA male jacks (see attached image). Plug the 3.5mm jack to your iPhone and the RCA jacks (red & white or red & black) to your Denon Receiver's CD in or Tape 1 or 2 PB (at the rear of the unit). Then select the input where you plugged the RCA to (front of receiver: CD / Tape-2 / Tape-1). Hope this will help. 25303676-z0ul41frrnrex4ege2epffps-1-0.jpg
Dec 02, 2014 | Denon Audio Players & Recorders
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
The cord will not stay in the receiver
There should be a little clip to retain the cord in the handset. If this clip is gone, the cord needs replacing. This clip is a plastic protrusion on the clear (most of the time) connector to the handset or phone. This clip must be depressed in order to remove the cord. If it has been forced and broke off, it will not longer retain the cord.
Cables and cord as well as connectors can be purchased and installed quite easily.
Oct 12, 2010 | RCA 25404RE3 Corded Phone
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
What does speaker cord for eT3205 look like? May not have been in
No question is stupid but it would help if you gave more information.
The basic cord for any speaker is 1/8" audio connector...
Nov 07, 2009 | Audio Players & Recorders
How do you get pictures on to your computer if you dont have a memory-card inserted?
your camera should have come with a cable that plugs into a usb port on the computer andplugs into something like one of these on the camera
usb-5pin-mini-m.jpg usb-5pin-mini-f.jpg 5-pin male mini connector, replaces B connector 5-pin mini female connector, used on most new Cameras, GPS Units, Cell Phones, Mini Hubs, Mini Hard Drives, Harmony Remotes, etc usb-pin-mini-m.jpg usb-pin-mini-f.jpg 4-pin mini male connector, replaces B connector 4-pin mini female connector, used on many older cameras; Olympus, Sony, Minolta, Kodak and Epson usb-nikon-m.jpg
Oct 17, 2009 | Cameras
No sound on my kam uhf wireless mike
wire loose inside handset, or receiver output problem. wiggle the handset wires and listen for crackling. if so, repair or replace.
Jan 26, 2009 | RCA EZLINX 3 BNC male plus 2 male to...
Repair usb power male connector snapped off
You can buy a mini usb cord from any computer shop. You can also use one from a digital camera if it has a mini USB slot.
Oct 14, 2008 | Garmin Nuvi 660 GPS Receiver
Top Native Union Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Native Union Audio Player and Recorder Expert? Answer questions, earn points and help others
