Question about Jenn-Air 30 in. CCG2423 Gas Cooktop
Dacor BBq ignitors won't stop sparking - Jenn-Air 30 in. CCG2423 Gas Cooktop
After cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
Jun 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
My ignitor will not go off. The burner will light
Unplug the appliance for at least 1/2 hour and then plug it back in and see if the problem goes away. If not, you may have a defective ignition board or a bad connection somwhere.
Aug 01, 2009 | Dacor Preference SGM304 Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Dacor SGG365 one burner control won't cause spark
your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
Oct 22, 2008 | Cooktops
Dacor ignitor keeps clicking
Dacor has updated ignitors with a broad head. Install the new ones and it will very likely cure the problem. You'll need a special spanner wrench to remove the burners. And watch out for the flying keeper clips.
Oct 06, 2007 | Dacor Preference SGM365SS Gas Cooktop
Dacor SGM304... no ignition
There is no fuses, as long as you have a power supply into unit then the only item that can cause this fault is a faulty spark generator.the hob will need to be dismatled to repair, remove the knobs, remove the burners and then remove the obvious screws, top will lift off Regards Advisor
Sep 01, 2007 | Dacor Preference SGM304 Gas Cooktop
Jenn-Air 30 in. CCG2423 Gas Cooktop Logo
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
