SOURCE: Washing Machine Will Not Drain
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
SOURCE: fabric conditioner drawer does not empty
The inlet to the conditioner compartment is probably blocked.
Get a thin piece of flexible wire and make a right angled bend on the end about 1" long, and poke it into all the holes u can see in the top of the dispenser compartment, particularly the ones at the front right side.
This should solve the prob.
Plz rate this solution .
Thanks
SOURCE: Bosch Exxcel 1200 Express Washing
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is [email protected]
