Question about Vacuums
Wipers and park lock wont work.they bolth go to the same fuse,fuse is ok.
  • Vacuums Master
  • 7,365 Answers
The question was put in the sewing machine catagory,it needs to be put in a different catagory so you can get help
Posted on Jul 31, 2013
How do I repair a 08 nissan murano the wiper linage fell off but the wiper motor is still running?
I think you would want to ask this in automotive repair. this section is for vacuum cleaners
Feb 01, 2015 | Manley 2008 NISSAN MURANO 14019-1 Sport...
My electrolux vitesse pet lover 1800w has stopped working
Is the flex all right? Check it with a voltmeter or a continuity meter (available for a small sum in your local hardware or electrical shop).
Jan 19, 2015 | Electrolux Vacuums
What is the best way to unclog the tubing from the shampoo container to the water supply. My machine, I thought, was working well! Then I realized I did not see movement in tank of shampoo and the carpet...
the machine has to run for few minutes in the parked postion to heat the water or it will not dispense, for one for twoif you turn the heat off and add hot water to the tank instead it will bypass the heating and work in the meantime best way to unclog after following these steps is there is an airlock in tline turn heat off in parked position and motor on hold the trigger down for about 15 to 20 seconds release and turn off, then in parked position (locked) upright pull trigger and hold then turn on power you then will have ceased the airlock if you want to clean the unit after trying this baking soda and apple cider vinegar is best, drop the handle to ground pull the tank out and loof for the round area that the tank plug goes into take a push pin and poke the holes, then dump the baking soda and vinegar that is mixed from a cup by a few drops to sizzle in there, lift and lock and turn on holding the trigger and there ya go, have fun
Jan 02, 2015 | Bissell Brushroll Proheat 2X 8920 9200...
Our dirt devil bagless upright (110002) stopped working while vacuuming. we cleaned everything out and cannot get it to start again. the motor is warm, but does not smell hot. is there a reset...
Hi, no im afraid its not that easy, the problem is with the wire that goes into the vac from the mains, now you see where the mains lead goes through in the back of the vac well what happens is when you vacing and moving the vac around this part wears and causes a short or loss of connection, now it usually happens when your using it then the free cable runs out and it pulls on the vac when you try goign further than the wire reaches, so the problem you are having is with the connection between the wire and the on/off switch, this is a very common fault with all vacs of this type.
to fix it your going to need to remove the cylinder and see if their is an access panel on the front of the vac behind the cylinder you take off to empty.
how ever if you have no electrical skills then its not safe for me to tell you how to do this repair, if you get it wrong you could do harm to anyone who uses the vac ok so be warned i have told you this ok.
the work involves removing the panel the other side of the switch then you need to undo the wires going to the switch you then need to pull the mains wire out of the vac so its no longer connected then cut it back 3 or 4 inches so as the part that is faulty has gone then you need to fit it all back together the right way round and make sure their is no bare wire showing and that it is all secure and then it should work.
but before you do all that check the fuse in the plug first as if its got hot this fuse may have blown so i would check that first before you decide what to do next ok.
it wont cost much to pay someone to do this as it wont require any parts, if you could take it to a reapir shop yourself then that will be even cheaper as you wont be paying a call out fee, also check if you have any warranty left on it as this fault wil be covered
let me know how you get on or if you need further assistance ok
please can you rate this solution as i have a whole page of unrated posts, thanks
Feb 19, 2011 | Dirt Devil M086700 Vision Bagless Upright...
My dyson dc14 wont turn on at all
Hi I would suggest you first check the Fuse in the plug. This is quite common.
If after chnaging the fuse the machine still doesnt work then please come back to us. Let us know that you have checked the fuse andthe machine still wont switch on.
Im confident it will only be the fuse. Unless you have had strange noises or funny smells coming from the machine.
Oct 26, 2010 | Dyson DC14 All Floors Upright Vacuum...
My Hoover Z 400 collapsible vacuum won't lock in the upright position. I pull the pin to change from a cannister to an upright, but the unit won't lock into position
this just happened to me. i took the vacuum completely apart and found that there is a locking plastic "tooth". this had snapped off but still it the track. the damage was bad but i was able to wash of all the lube off it and used a 2 part epoxy glue to put the tooth back into place. it works ok now. Not like new but it will hold. this was sorta easy but i enjoy fixing things. If your not handy i wouldnt recommend you try it. i am in the process to making an aluminum version of the tooth so it wont break again.
Dec 24, 2009 | Hoover F5858-910 SteamVac Vacuum
Kirby wont come back on checked outlet its ok
If you are refitting the shampoo tank, you havent turned it far enough. There is a safety switch that must lock
Mar 07, 2009 | Kirby Ultimate G Bagged Upright Vacuum
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Vacuums Logo
15 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
