Question about Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Drip tray - Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Heat exchanger line frosting up. Then drips on the floor
The condensate bucket may be missing or installed incorrectly. In some dehumidifiers poor design causes condensate to drip onto the floor.
Apr 21, 2015 | Haier 45-Pint Dehumidifier
De500 pump failure
I agree with Mike Kolbay's earlier very complete answer. The water intake to the pump is quite narrow, and clogs easily with accumulated lint and bacterial muck. While the covers are off the machine, thoroughly clean the drip tray and all the water passages. A piece of crud the size of your smallest fingernail can cause water to overflow onto the floor, rather than going into the tank.
Sep 06, 2012 | DeLonghi DE500 Dehumidifier
Tasciugo dehumidifer about 10 years old has started to leak. I have cleaned filter and spout water drips from is there anything else I should do. ?
Drips from where?
Find the source of the drip and seal it with rubber or waterproof tape.
If there is no pressure at the leak, this should cure it.
If you have trouble locating the leak, dry off everything and operate the
dehumidifier while you watch for the appearance of the moisture. Where
it first appears is probably the leaking location.
Aug 29, 2011 | DeLonghi Dehumidifiers
My Frigidaire dehumidifier no longer drips water into the bucket but drips oil. What happened?
You have a leak in the refrigeration system...that is why it is not cooling and condensing water and why it is dripping oil...
Here is a tip that I wrote to help people tofigure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 26, 2011 | Frigidaire FDR25S1 Dehumidifier
I have a hose discharging water from back . but bucket still fills up. ive checked hose for clogs ive checked pump for proper operation. ive tried to block drip spouts going to bucket that just made water...
The clog is not in the hose. It's in the hose connection tube inside the unit. To unclog it use an 18" long plastic Zip Tie or something similar that is flexible and will fit into the hole. NO wire coat hangers though. Gingerly work it into the hose connection hose, until you reach a bend in the tubing. This is the tricky part, as you have to get past this bend. Be careful and work it past the bend. Once the Zip Tie bottoms out or you run out of Zip Tie, slowly pull it back out while rotating it. This will dislodge the clog. Once the Tie is almost all the way out, be prepared for water to follow.
One other thing. If the unit stops operating check that the bucket full light is illuminated. If it is remove the bucket and empty the contents and then check the seal between the hose and the drip tray. If there is a small leak then replace the hose gasket and re-tighten the hose.
FYI - Your humidifier does not have a pump. It relies entirely on gravity to drain, when you use the hose connection.
That should solve the problem.
May 22, 2011 | Frigidaire FAD504TDD Dehumidifier
Machine works, but no water collecting
A dehumidifier is basically a cooler. The condenser coil on the outside should feel cold to the touch usually around 34 to 38 degrees, as air passes over the coils they collect the humidity in the air and it then drips down into a collector tray. If the coil does not feel cold it is ether a bad control switch not letting the cooler (compressor) turn on, low on freon, or burned out compressor
Oct 07, 2009 | Haier 45-Pint Dehumidifier
Dehumidifier leaks
Either there is a hole/leak in the tray, or the drain line is clogged. You are giong to have to access the tray to determine this: standing water is plugged line and no water is busted pan. This will determine your avenue of approach.....
Aug 31, 2009 | Ebac Neptune Dehumidifier
Water in the floor
Not sure what you are calling the "collector". Most of the time, problems like this are caused by a build up of gunk at the point where the water, which has condensed and dripped down into a tray, leave the try and is suppose to go either into the water bucket or out the drain hose if that is attached. Because this area gets plugged up, the water has to go some where else, which results in leakage over the side of aforementioned tray.
The best solution is to remove all the covers to get to this drain area and clean it out, but that is a pain to do. I'd suggest trying to run a pipe cleaner or nylon wire tie back up into the area where the water is suppose to leave the dehumidifier on it's way to the bucket or hose. Flushing some water back that way with a turkey baster might work also, but would result in some splashing, causing a little additional temporary leakage.
Jul 26, 2009 | Maytag M7DH65B2A Dehumidifier
Water dripping outside the collector
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
Aug 24, 2008 | LG LHD45EL Dehumidifier
Dehumidifiers Logo
15 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
