Question about Boating
My 1999 Yamaha 80TRY outboard has repeated starting problems due to plugged idle jets after sitting three weeks. Mechanic says it is due to today's gas formula (live in Calif). Have installed new gas tanks and gas is only 2 months old. Open to all suggestions how to fix.
    Sergeant:
  • 456 Answers
Try manual choke,red lever on centre carb,turn fully clockwise,fuel should not give probs after 3 weeks.is motor swinging fast
Posted on Oct 22, 2013
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 57 Answers
SOURCE: 1987 225 Evinrude will not stay idling. Will start
is your idle speed high enuf? have you checked timing-i know sounds silly but
Posted on Jul 13, 2009
SOURCE: motor kills when put into gear
u have no spark in #2 cyl check for spark with plug if its week regap it
Posted on Jul 14, 2009
  • 10865 Answers
SOURCE: 6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Posted on Sep 16, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
Outboard seems to flood out at idle/low rpms
Check plugs had the same problem with 25hpJjohnson changed to hotter NGK plug and started using 89 obtain gas problem solved this is a ethanol gas problem
Jul 17, 2016 | Light Outboard Motor Boat Bass Fishing...
Motor will run on starting fluid but wont stay running
Did it sit for a long time with gas in it?
Your idle jet(s)/circuit is plugged up.
When gas sits too long, the components start to separate, and it turns almost into a varnish.
This starts to plug up the jets and passages, starting with the smallest, which happens to be the idle circuit and jet.
Clean out the carb, paying attention to the jet and the passage drilled in the carb body.
Feb 10, 2014 | Yamaha Motorcycles
Yamaha zuma wont idle. has fresh gas, new battery, new spark plug and what looks like a clean carburetor. Starts fine, but cuts out quickly.
It sounds like it has been sitting for some time. If it has then the idle jets in the carbs need to be cleaned out, they have the smallest holes and clog easy from sitting too long. Fuel stablizers can help reduce this problem, running the engine once or twice a month works best for me to prevent clogged jets.
Sep 07, 2013 | Yamaha Motorcycles
I need a carb diagram for yamaha tzr 250 cc motor cycle year 1988 it will not rev with out choke on . blocked jets?
Hi, Rolandwhitfo and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
TZR 250 WON START
Will start but wont stay running without choke Yamaha Outboard Parts Forum
Yamaha TZR250 1987 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-tz-owners-manuals
Aug 08, 2011 | 1988 Yamaha TZR 250
Hit the gas and the engine almost dies. Idles and starts fine. Changed the spark plug - no change.
What kind of bike? It sounds like clogged carbs, if pilot jets are plugged from lack of service or sitting for a while then your bike could still start but will fall on its face when opening throttle due to lack of fuel, solution=clean your carbs thoroughly and flush your tank.
Jun 10, 2011 | Yamaha B50 Cross Junior Motorcycles
Yamaha 2001 ttr 250. Bogs above half speed, under load
I have the same problems with my 1999 TTR 250, were you able to find out anything?
Walt
goalhawk@hotmail.com
May 04, 2010 | 2002 Yamaha TT-R 250
I have a 2005 Yamaha FZ1 Fazer. It has covered 3800 miles from new and is as new. It resides in our holiday home in Florida. If I leave it for longer than two to three weeks all the primary and idle jets...
Todays fuels are different than they were even a few years ago.
I would suggest you turn off the petcock and run the bike out of gas before storing it - this will take several minutes of idling. This would eliminate fuel sitting in the carbs while it's not in use. I think this is what I would do if I was in your situation.
Feb 23, 2010 | 2005 Yamaha FZS 1000 Fazer
1990 virago 535 starts and runs great for about 3 or 4 miles
Pull the float bowl caps off the carbs and then spray carb cleaner into the main jet and all other accessible ports on the carbs. Chances are there is a build up of water condensation in the carbs.
Aug 03, 2009 | 1990 Yamaha XV 535 Virago DX
Motor kills when put into gear
Feb 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
54 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
