Question about Hotpoint Dryers
I've recently moved house and since then my Hotpoint condenser dryer appears to have water around the drum. When plugged in, it trips the electricity. Is there anything I can do to rectify the problem? Please help
  • 7,365 Answers
Your question was put in the sewing machine catagory,, it needs to be put in another catagory, so someone can help you.
Posted on Jul 31, 2013
Bgillespie
  • 89 Answers
SOURCE: Kenmore 90 Plus Series Electric Dryer trip
It sounds like the motor switch which is actually inside the motor on the model. It is very expensive to replace motor so it may not be worth fixing......
Although I stick to the above statement; I have seen cases where a thermal fuse wire has come loose and perhaps sometimes touching(allowing heat) and sometimes not(hitting something blowing the breaker.... Check all wires on blower vent area... GOODLUCK!!!
Posted on Dec 17, 2007
  • 139 Answers
SOURCE: Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Posted on Jan 21, 2008
  • 3 Answers
SOURCE: Tumble dryer trips electricity
I own the same machine and this happened to me, if the internal working of the machine get wet it will cut off causing the electrics to trip. This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced. If water has built up in the machine you will also need to check to make sure none is sitting in the heater coil compartment (it did with mine) to get at this you will have to unscrew the metal plate at the back of the machine and let any water out. Leave the machine for a few hours to make sure it is dry and then give it another go. If your machine is still under warranty though i would call indesit first as they may get a little funny if you remove any of the machine covers yourself and refuse to look at your machine.
Posted on May 28, 2009
barkencoa
  • 3463 Answers
SOURCE: tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Posted on Feb 01, 2010
Testimonial: "Straight-Forward answers, quick - ace!"
SOURCE: Hotpoint Aquarius condenser dryer model no. TCL770
we had this, and it turned out to be the plug getting damp at the back of the dryer due to inadequate ventilation at the back of the dryer...we pulled the dryer away from the wall slightly, allowed the plug to dry out for a few days and the problem was solved.
Posted on Mar 22, 2010
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
Hotpoint TDC32P condenser tank not filling
you should read the catalogue.
Mar 26, 2013 | Dryers
We recently bought a new Hotpoint WMF760P washing machine and within a couple of weeks of using it noticed that it kept tripping all of the electrics out in the house, when it goes into it's final fast...
I have seen this before with a number of machines when they were a little overloaded. I've never been convinced that I understood why it happened, though I always suspected a motor overload of some kind causing the issue. This said. There is absolutely no reason for a machine to trip the mains unless it's faulty.
If you have a friendly neighbour who doesn't mind you killing the power in their house, you could always run an extension lead from a neighbour to your house and see if it kills their power too. But like I say, at the end of the day, if it trips the power and you have your electrics checked, then I would INSIST that you get a replacement from Hotpoint. Things that use water and electricity are not to be messed with!
Sep 08, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
I have a new (1 month old) Hotpoint Condenser Dryer (TCD980G). When it is on the drying cycle it runs for about 30 minutes and then trips the RCD circuit. I have cleaned the condenser filter and the water...
There should be no condensation present if it is a condenser dryer, this is the idea of it.
As for tripping the electrice, then it suggests to me that the steam could be the cause of the problem.
As it is a new dryer, then I would strongly advise you ring Hotpoint service, or ring the help line number in your instruction book.
You can contact them at the following address if needed.
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Hotpoint condenser dryer drum workinbg no heat
check the temperature switches in the back for continuity and also the moisture sensor on the exhaust housing at the rear of the unit. all these switches should be normally closed.
good luck...jay
Apr 23, 2009 | Hotpoint Dryers
Tumble dryer when switched on cuts power to all sockets in house
Hi.
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Hotpoint CTD00 trips the power
This happened to me.
Your condenser unit on the front bottom left corner may be clogged up and causing water to back up around the fan and heating element behind the rear panel.
Take condenser unit out and give it a good clean removing as much fluff as possible.
If the heating element senses damp on it, then it will trip the electric.
The back panel which is at 45 degree angle on back. I took this off and sure enough there was water in there.
Wipe away all water and use an ever so slightly damp cloth to remove as much dust stuck to the metal as possible.
I used a hair dryer for about ten minutes fanning over the heating element and circular fan. Don't rush this. Take your time to make sure all signs of damp have been removed from heating element before putting the back panel back on.
After carrying out the above my machine worked fine and no longered trip electric.
It is a pain, but to prevent this problem happening I suggest cleaning condenser unit about once a week if you have alot of washing. Empty water panel after every two loads, maximum.
Good luck
Jon
Oct 24, 2007 | Dryers
Dryers Logo
47 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
