Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
We are getting a low salt warning on the salt water pump. the salt is not low we had the water tested. the pump keeps beeping. we have unplugged the unit and it still keeps beeping. please help Dee Jones (deajones818@yahoo.com)
    Problem Solver:
  • 7 Answers
As mentioned on another response, we find we have to add a *lot more salt than in the manual - around twice as much. We're in Wales in the UK & I'm not sure whether our climate is different to what's expected - probably cooler than for many pool owners, even though it's under cover!
Posted on Nov 23, 2013
  • 297 Answers
SOURCE: My Salt water pump keeps saying it is low on salt.
What is plenty of salt? There is a specific amount that you need Can't guess at it.
You must be above 2800ppm and no higher than 3800ppm
3000ppm is the best
You will need test strips for salt that reads in numbers not color
High salt can also trigger a LOW salt alarm
Don't ask me, it just happens
Just remeber 3000ppm
Posted on Jul 03, 2010
  • 297 Answers
SOURCE: intex salt water witha 18x48 witha 2000/gph pump.
nothing is wrong that you cant fix
you must have your salt no lower than 2800ppm
3000ppm is the best
make sure you run filter only for 24 hours once you have correct salt then start generating
one last thing test with strips that read #'s not the color strips
SOURCE: Low salt alarm on Intex system
I had the same problem and my father just kept adding salt wo telling me and it kept saying low salt-I called intex they said to clean the cell with vinegar as instructed in book, and if that didnt help to call back for a warranty claim on the unit bc I just purchased mine in June. I am currently waiting on it to come in. We had to drain half the pool and refill with water and start over. be careful!
Posted on Jul 29, 2010
GodBlessU
  • 3513 Answers
SOURCE: i have an intex above
Hi
The Intex system has an LED that displays various codes when a problem occurs. After one hour of the code flashing and the system beeping, the unit will turn off and not produce any chlorine.
Check the screen for the code that is being displayed. If the unit has turned off, press either the down or up arrow button below the screen to see the last code displayed.
Refer to the owner's manual to identify the code and the meaning. There are three codes that can display. Code 90 is low or no water flow, code 91 is low salt and code 92 is high salt.
Code 90 means the filter is not on, the hoses are clogged, the filter is clogged or the water is flowing in the wrong direction.
There are several things you may need to check and do:
- Ensure the pool pump is on and running.
- Ensure the plunger valves on the pool (if any) are opened.
- Ensure the filter cartridge, cell and debris screen are clean from debris and dirt.
- Ensure the flow sensor (especially the hinge) is clean. See Owner's Manual. Release all trapped air (if any) in the circulation line hose.
- Check he direction of water inlet and water outlet hose. Reverse the hoses if incorrectly connected.
- Check if the flow sensor is loose or not connected properly. If not, please plug the flow sensor firmly into the flow sensor receptacle.
- If code 90 still appears despite above steps, there might be a flow sensor failure. Please contact Intex Service Center for replacement.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 20, 2011
  • 368 Answers
SOURCE: My salt water pump keeps
I suggest you clean the cell according to manual and try it then. If it keeps producing chlorine then keep swimming. If the pump is flowing water fully (if not clean baskets and filter) and it can't keep the chlorine above 2 ppm and you have 30 to 50 ppm stabilizer in the water then there is a major problem in the chlorinator. I don't trust the salt indicator on some chlorinators but that is less important than if it chlorinates. You can but salt test strips. I hope this helps.
Posted on Aug 13, 2011
My salt water pump keeps saying low salt. I have had the water checked and there is plenty of salt. I have cleaned the cell and it still says low salt. The pump is on;y 1 year old. I dont know what else to...
Aug 12, 2011 | Intex Automatic Salt Water System for ...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
I have a 12,000 gallon abg pool Also the water is from a well system The low salt warning light came on I then cleaned the cell and reinstalled the cell only to have the High salt light come on I then...
any thing over 3500 can create alarms.
First of all make sure you are useing a test kit for salt that reads in #'s not color
your system can read low salt when it is high or even high can read low
The system only really knows something is wrong
your 7800ppm is ridiculously high
Now start draining 20% of your water at a time and refilling giving the system at least 6 hours of just filtering between drainings until you get to as close to 3000ppm as possible
under 2700ppm and you will not produce enough chlorine and can trigger alarms any higher than 3500ppm and you can trigger alarms,go cloudy, and not to mention corode any metal parts like an aluminum ladder
once you get the ppm to 3000 clean your cell one last time and you should be good to go
I would also check your water for metals since you used well water.
you may need to get a metal reducer to add to the pool
Aug 05, 2010 | Intex Automatic Salt Water System for ...
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
Intex salt water witha 18x48 witha 2000/gph pump. my salt water system keeps saying low salt... my salt tested fine after adding more and ive cleaned the cell... it will stay on about 20 min then beeps low...
3000ppm is the best
Jul 03, 2010 | Intex Automatic Salt Water System for ...
so what does the test strip say. Should be as close to 3000ppm as possible anything close and under 2700ppm will trigger a low salt also you must run filter only for 24 hours to thouroughly mix the salt before trying to turn on the generator
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
64 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
