Question about Midwest Trading Group SoundLogic XT BSS-2/5581
How do I connect sound logic base capsule wireless speaker to my laptop
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
I used to have a linksys router but now have a Apple Time Machine. When I power up my WGA54G all i get is the power light. When I connect my WGA54G to the Time Machine, only the ethernet and power are lit....
Well, I'm not quite sure what your asking, exactly, but I'll try,
What are you wanting to connect the 'WGA to?
--"I used to have a linksys router but now have a Apple Time Machine."--
The Apple "Time Machine" is the backup "software" that controls the "Time CAPSULE'S" Hard Drive so I'll take it you mean the Time Capsule. The Time Capsule is already wireless.
The Time Capsule is just a wireless router with a Hard Drive in it. You should have set the Time Capsule up the same way you did the Linksys router. The Time Machine software on your computer can now access the Hard Drive for backup purposes.
"Time Capsule" connects to the '"WGA" wirelessly
'"WGA" is connected to a"Game system" (or network ready non-wireless product) via the Ethernet cable.
-"When I connect my WGA54G to the Time Machine,"-
OK,,,,,,, After looking at the manual on-line I think I know what happened, I believe the Manual is wrong! The "NOTE" mentioned to hook it to the Router first but how the heck are you suppose to access it from there? You CAN'T!
I think they had a "Brain Fade" and meant to hook it to the computer.
Hook the 'WGA to the Mac Book Pro and you should be able to access it now. You might want to make sure the MBP's Network connection LOCATION is set to AUTO to make sure it connects OK.
Make sure the switch on the side of the 'WGA is set to - infra- and not -ad-hoc-.
Hook an Ethernet cable to the computer then hook the other end to the 'WGA then plug the power cord into the WGA to turn it on and then try the Ip # it said to use in a web browser. If it then shows the log-in screen then enter them in like the manual said.
According to the manual if you can't access the 'WGA via the IP #192.168.1.250 then it some how got changed and you will have to reset it like the manual say's.
I hope I understood you OK, Good luck....
Jan 07, 2011 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Trying to update firmware on y airport extreme but i forgot my password
You need to perform a soft reset of your router. There directions to do this from the Apple web site are:
  1. Connect the AirPort Base Station or Time Capsule to power.
  2. Press and hold the reset button with a pen or pencil for 1 full second, then release it. The light (LED) will begin flashing amber, indicating that the AirPort Base Station or Time Capsule is in soft reset mode.
  3. From the AirPort menu bar item, choose the network created by the AirPort Base Station or Time Capsule (the network name does not change).
  4. Open AirPort Utility in Applications > Utilities on a Mac using Mac OS X, and in Start > All Programs > AirPort on a computer using Windows.
  5. Select the AirPort Base Station or Time Capsule and click Continue.
  6. A window indicating that the device has been reset will appear.
  7. Select "Restore the previous settings" and select OK.
  8. Move through subsequent windows to make changes to your passwords or other settings as desired, clicking Continue after each one.
  9. When you have moved through all of the selection windows you will be able to select Update. Click Update to install the new settings.
  10. Click Continue to allow your AirPort Base Station or Time Capsule to restart.
  11. Quit AirPort Utility.
These directions are from the Apple Support Web Site:
http://support.apple.com/kb/ht3728
Jan 02, 2011 | Apple AirPort Extreme Base Station
Won't connect to Apple Time Capsule
change the security type from WPA to WEP bu logging in to the router....
this will resolve the issue....
Apr 20, 2010 | Linksys (WPC54GS) 802.11g/b Wireless...
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Wireless internet connection
go into start, connect to, show all connections, click on lan connection, right click on it, repair connection
Oct 17, 2009 | HP G60t Notebook
Brookstone Wireless Rechargeable Speakers with auto-tuning
its probably the interference with the routers. try getting internet by bypassing the router. much easier sound quality.
Jun 12, 2008 | Brookstone Outdoor Wireless Speaker...
Midwest Trading Group SoundLogic XT BSS-2/5581 Logo
50 people viewed this question
Top Midwest Trading Group Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Midwest Trading Group Audio Player and Recorder Expert? Answer questions, earn points and help others
