Question about Remington RM4022H 22-Inch Dual Action 4 Amp Motor 3/4-Inch Cut Electric Hedge Trimmer
What do need to do? My trimmer is starting to smoke. Do I oil it or what?
  • David Johnson Jul 31, 2013
    This trimmer is electric. There is no place to put oil or gas mixture. Still smoking .
  • Plink-plonk
    Plink-plonk Jul 31, 2013
    Electric motors shouldn't smoke.. They may ofren flash, this is normal, its just the brushes on the motor but the motor itself shoudn smoke.. I'd advise using caution .:)
  • Remington Master
  • 1,807 Answers
If its smoking reom the exhaust the no, its smoking because its probably running too rich or there is too much oil in the fuel (incorrect mixture)
Posted on Jul 31, 2013
Testimonial: "This trimmer is electric it has no gas mixture or a place to put oil."
White smoke from p1500 trimmer
Too much oil in the gas or water in the gas
Drain the gas, refill with fresh clean oil/gas mixture
Apr 03, 2016 | Poulan 25cc 2-Cycle Gas Powered String...
Excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My Stihl FS55 Trimmer gets a small amount of white smoke under full throttle, is that normal?
I recategorized this for you.
Yes, I would say that is normal as they are two stroke and burn oil to lubricate the piston, bore and crankshaft. If it smokes, you know it is OK. At full throttle it needs more oil.
Oct 30, 2015 | Stihl Garden
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
Starts but will not stay running. smoke blows out the back, would this have anything to do with the gas/oil mixture?
These amchines smoke a little, but if it is smoking a lot,.....either the gas/oil fuel mix has too much oil or the engine is badly worn. If it is the engine, power and acceleration will be lacking . Too much oil in the gas may eventually foul the plug...lest you mix up a batch at the proper ratio. 40:1 is good. 3.2 oz 2-Cycle oil to ONE gallon of gasoline. Always use fresh fuel in these small engines. If the mix is over 1 month old, dump it back into the can, pour it all into your car (won't hurt it) and make some new.
Aug 26, 2010 | Troy Bilt 17 Inch 29 Cc Gas Powered...
I put to much oil in my weed eater, lot of blue smoke came out, then it stopped. if i pour some of the oil out and let it cool off will it be ok
should be ok drain oil to correct level remove spark plug clean and dry plug,with plug out crank over to remove oil from cylender,make sure air filter did not get oil soaked if dry reinstall if wet replace. reinstall spark plug and start probably will smoke untill it burns off residual oil in muffler hope this helps
Aug 09, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Homelite gas trimmer ut20602 from 1998 need oil mix ratio...is it 40:1 or 50:1
Use the 50:1 ratio oil mix.the oil bottle will tell you how much oil that you will need to mix with how much gas you have,40:1 will make the trimmer smoke too much and it will foul plugs prematurely but won't hurt the machine.
Jul 30, 2010 | Homelite Mighty Lite Lawn Trimmer
Fuel mixture ratio
50:1 with fully synthetic 2-cycle oil, 25:1 with semi-synthetic or mineral oil.
I use synthetic oil at 50:1 - more power, no smoke, and no fouled plugs.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Having problems starting Makita strimmer. There is quite a lot of smoke coming out and then it stops. Have looked at spark plug -clean, and cleaned air filter. Could the problem be the petrol and oil mix.
Use 50:1 gas/oil with a GOOD QUALITY 2-cycle low-ash synthetic oil.
Remove the muffler and check the spark arrestor isn't partially blocked.
With a clear muffler, and the mix as described, there will be hardly any smoke at all.
May 09, 2010 | Black & Decker String Trimmer Cordless 12"...
Oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
Jan 17, 2009 | Homelite Factory Reconditioned 26cc...
Remington RM4022H 22-Inch Dual Action 4 Amp Motor 3/4-Inch Cut Electric Hedge Trimmer Logo
167 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
