Question about KitchenAid KERA205PSS Electric Kitchen Range
Oven door does not completely close - KitchenAid KERA205PSS Electric Kitchen Range
4 Suggested Answers
  • 147 Answers
SOURCE: bottom door doesn't close completely, often (but
REPLCE THE HINGES
Posted on Dec 26, 2010
  • 552 Answers
SOURCE: The oven door does not completely close and
Hello
You have the same problem the door hinges need to be replaced to fix this issue again.
This is a very common issue on these units, replace the hinges to fix this issue.
http://www.appliancerepairlesson.com/
Posted on Mar 06, 2011
  • 489 Answers
SOURCE: Lower oven door
here is my video might help you.
Posted on Nov 21, 2015
I have a panasonic microwave genius protege type AP104A which will not always work after closing the door
Closing the door operates a switch or switches which function as an interlock to prevent the oven from starting unless the door is closed completely. The switch or switches may be defective or misadjusted. Also, the door may not be closing properly to close the switch(es).
Dec 07, 2013 | Panasonic Microwave Ovens
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Apr 21, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Adjustment to door hinge, as door does not close completely
In most cases door hinges needs to be replace but some time with old stile ovens and ranges help this trik:
1. Put small towels on right and left hinge between the door and range/oven body
2. Close door and gently push like you try to close completely.
3. Try several times.
4. Open door, remove towels and see if it helps
5. If not replace hinges
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 29, 2008 | DeLonghi Kitchen Ranges
Lower oven door
Mar 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
KitchenAid KERA205PSS Electric Kitchen Range Logo
20 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
