Question about Air Tools & Compressors
I have a CompAir SR120. I keep getting a SR Over Current fault at start up. Circuit boards have been changed, diodes and comm cable. Fault still exist. This is a relatively new compressor. Any ideas as to what may be causing this fault to continue?
Astinsan
  • 87 Answers
SOURCE: top of form fault
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Hope this helps you.
Posted on Nov 22, 2008
  • 653 Answers
SOURCE: Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Posted on Feb 27, 2009
  • 5603 Answers
SOURCE: R.S.U probe fault on a hydrovane 845
RSU stands for Rotor Stator Unit.
If you just fitted a new motor DO check the rotation direction is what it is supposed to be.
Posted on Nov 19, 2009
  • 343 Answers
SOURCE: main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
Posted on Jun 02, 2010
Testimonial: "thanks so much for your help"
  • 59 Answers
SOURCE: Power indicator /red/ and warning led/red/ are
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Posted on Jan 20, 2011
Why does the relay in my RCA TV click on then off when the power button is pressed? Isn't the 220v at the horizontal output too high when just plugged in ?
I don't have your previous question but rest assured that diodes do not reduce voltage
their soul purpose in electronics is to act as a one way valve for current flow
they flow from positive to negative but stop reverse current negative back to positive ( hence their application on a rectifier bank to change ac current into dc current)
Resistors drop voltage by dropping current flow
Oct 24, 2015 | RCA Televison & Video
Tip
Monitor led is blinking or steady, but the display does not come up
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
on Apr 22, 2009 | Dell E173FP 17" LCD Monitor
Check engine light came on
What do you mean "can't find code"? If the check engine light is on, there is a fault code stored in your onboard computer - that's the way it works. If you are using a generic OBD code reader, that is most likely the reason you cannot find any codes. You need to use a scanner that has the correct software to access your ENTIRE computer network, not just the "continuous memory" or "generic" side of your computer system.
The window problem is a seperate problem and must be diagnosed accordingly.
Apr 23, 2012 | Daewoo Matiz Cars & Trucks
Goldstar tv CI-14A80A keeps blowing the circuit board ceramic fuse
TRY TO CHANGE THE POWER REGULATOR, WHICH IS LOCATED NEAR THE THE CAPACITOR, COMMON FAULT..WITH THIS THE ZENER DIODE CAN BE ALSO DAMAGED, ITS ALSO NEAR THE REGULATOR..FULL SERVICE THE BOARD....SHOULD BE WORKING THEN
Oct 13, 2009 | Televison & Video
17" dell monitor
  • Video cable.
  • Motherboard.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Dell monitor 17'' just blinks, will not give the dell logo???
  • Video cable.
  • Motherboard.
Monitor do not want to come on
  • Video cable.
  • Motherboard.
Feb 02, 2009 | HP W2007 LCD Monitor
Manitor is not working
  • Video cable.
  • Motherboard.
Jan 15, 2009 | TDV Vison TDV FV19B 19" Flat Panel LCD...
My monitor keeps blinking on and off its driving me nuts mu phone number is 814 853 1790
  • Video cable.
  • Motherboard.
Jan 11, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Samsung crt monitor
  • Video cable.
  • Motherboard.
Common faults that can occurr are a blown capacitor on power board, faulty convergence, fault on alignment circuits, flyback problem , or a fault on Digital board.
Jul 12, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
Air Tools & Compressors Logo
47 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
