Question about Kensington K39561US KeyFolio Expert Multi Angle Folio & Keyboard for
The power light is on but the keyboard is not working.
Why is keyboard not responding?
This answer relates to keyboard hardware issue only.
On powering on PC look for keyboard lights flashing.
If no flash. Power down. Remove/replace kbd plug.
If still no flash of lights then please read on.
If kbd is old ps/2 type. Which is small round, sometimes purple, plug.
Ensure its not in not in the similar mouse socket.
Check for bent pin in plug.
ps/2 sockets can fail (as can keyboards)
If no joy and no other ps/2 keyboard works, consider replacing with usb type.
If kbd is usb type, do power off/on look for lights flashing.
If no flash of lights, try in different usb port.
Try replacing keyboard.
Hope this helps.
Jul 24, 2015 | Dell Inspiron Computers & Internet
Keyboard quit working; blue charge light on
faulty power adapter port, may have blue light meaning charger is working normally, double check with another working power adapter or use your adapter with another keyboard to check which device has problem, power adapter or keyboard port.
Oct 12, 2014 | Targus 90W AC Universal Wall Power Adapter...
I plugged in the keyboard but it wont let me type anything? how do i make it work?
You should install the drivers and software for the keyboard first. If you have already done that, try plugging the keyboard into another available port on your computer.
Jan 08, 2011 | Logitech 967437-0403 Keyboard
Am using Win XP When I turn the pc on with recovery disk inserted the Press Any Key to boot from cd" screen comes up but pressing any key does not get a response then it continues on to the sign in...
OK! Lets troubleshoot this together.
First thing we want to do is verify that your keyboard & mouse and plugged into the correct places and are powered up and able to work.
Turn your computer on and look at your keyboard and tell me if any lights are on to show that it has power and is operational.
Watch the keyboard lights until the computer gets to the login page and tell me if the lights come on and stay on? Or do the lights turn on for a moment and then turn off again?
If you do not see any lights, please clarify if there are NO LIGHTS on your style of keyboard or if there are lights but they are not lighting up.
If your keyboard has lights and they are not lighting up at all, then turn off the computer and unplug the mouse and keyboard and swap them around. Then turn the computer on again and tell me if the lights come on and the mouse and keyboard become operational.
Once we verify this we can continue to the next step of troubleshooting. Please report what you find and I will help you solve this.
Nov 08, 2010 | IBM NetVista PC Desktop
Laptop keyboard doesnt work, extensa 5220 laptop . keyboard keys do nothing,boots up fine , and mouse functions fine, can get on facebook , but cant type anything.
Either something got spilled in it or the connection ribbon got jossled lose. The top power bezel should be in with clip snaps. Remove it then the keyboard should pop up after you lightly squeeze the sides in. Look under the keyboard there is a ribbon that connects with a lock snap. Lightly push the lock clip up and push the ribbon back in and snap the clip back on. Do not put it all together yet try booting it apart and try the keyboard. If it still doesnt work power down remove battery unplug it and finish removing the keyboard order u a new 1. They run around $20 brand new.
Mar 28, 2010 | Acer Computers & Internet
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
GEPower Keyboard Help - Worked before, but not now
Did you install the CD software program for the Keyboard?
The Keyboard should have been plugged in before you started your computer. Then you should have installed the CD program.
Also after installation if it doesn't work try the following:
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Aug 06, 2008 | GE Power Keyboard (97798)
My PC was unplugged before powering down it is an ACER, all that comes up not is DEl TO START UP AND F12 TO BOOT NETWORK...MY PC will not recognise my keybaord
Hi Tilley;
Power Off your PC
Remove Keyboard
Power ON your PC, do you see "No keyboard detected"? anyways
POwer Off your PC again
Now,insert back your keyboard, POWER ON and make sure you see 3 lights blink in your keyboard
better yet, use your keyboard on another PC just to make sure its working.
Hope this helps, i often do this procedure when my keyboard doesnt work...
Jun 21, 2008 | Computers & Internet
Logitech keyboard not working
i put my logiteck kb on sleep mode. Computer shut down next moring would not work for nothing Is there a power up sequence or somehting i need to do. Used to work, very strange.
Mar 14, 2008 | Logitech 967437-0403 Keyboard
Installing my wireless keyboard and mouse
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Feb 20, 2008 | Micro Innovations KB985W Keyboard
Kensington K39561US KeyFolio Expert Multi Angle Folio & Keyboard for Logo
13 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
rey francis basa
rey francis basa
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
