Question about Sony PlayStation 2 (PS2) Console
Playing Online I'm trying to plat onine. I set up my configuration and it was able to connect with the connection test. I reset the system but when I try to play online it tells me I have the wrong network connection. I did check to make sure nothing changed when I reset and everything is ok. I even did another connection test which was fine. Am I doing something wrong?
    Problem Solver:
  • 12 Answers
They're phasing out the server for ps3
Posted on Jan 16, 2008
SOURCE:
How do I reset my router and connect it to a different computer?
Look for a little hole that reads reset and press it with a little pin, hold it for about 10 seconds
Jan 31, 2012 | NetGear WGR614 Wireless Router
While playing cod black ops online I go into a match and after like 5 minutes it come up connection interrupt every time I go into a match
If your nat type is anything other than nat type 2 then you may have issues with playing online. To determine that run a test connection on your game system and it will tell you. Try resetting your modem/router and if that doesn't work you will have to get into the mode/router configurations via PC and put you console outside the firewall as a DMZ host. To help you with that I will need to know what isp you are using and will be able to help you set that up. Good luck!
Feb 09, 2011 | Video Game Consoles & Games
I cannot play call of duty black ops online. However, I can play any other game online. I have tried troubleshooting. I reset my router, had a friend bring his copy of the game over that he plays online...
Nat Type has to be 2 any other Nat Type will have conflicts with online play no matter what other black ops you try. Do a connection test from your PS3 and make sure the Nat Type is 2, if its not do a full reset on your mode/router if that doesn't work then you will have to get into your modems configurations via PC and set your PS3 as a DMZ host. I can help with that if you need the help. Good Luck!
Feb 08, 2011 | Sony Playstation 3 (PS3) Console
After installing the update i cant get online due to error console. Unable to scan for network due to undetectabilility.
Please clarify your problem.
Try resetting your modem and internet connections:
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and choose the appropriate settings. (What's highlighted is going to be the best option, continue to hit the right button on the analog to go through the stages.)
Be sure to choose "Wireless" when configuring the settings if you are using wi fi for connectivity.
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
PS3 keeps signing out. Won't let me play online. Still can use browser.
Does this happen all the time or just for today? If it's just for today and maybe a few times in the past, like all of us, then you will need to be patient and keep signing in or reset your modem to allow a new fresher connection. If you get signed out, press the PS button in the middle of the controller and sign back in swiftly and it should reconnect.
Reset your modem and run a test again:
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
The playstation was turned off while playing online and now the online connection is not working.
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Recover Password
there are two ways ..try them
first :
In order to set a new password do the following:
Make sure you have a console connection to the Foundry device.
Reset the device using the reset button in front or remove and then reinsert the power cable.
Immediately enter b to go to the boot monitor mode at the time of boot up.
Enter no password in boot monitor mode.
Enter boot system flash primary (or secondary).
At the prompt enter the following commands:
FastIron>enable
FastIron# configure terminal
FastIron(config)# enable super-user-password test
FastIron(config)# write memory
Your new password is now "test".
second... only try if first doesnt work
Set the switch to its default configuration. Make a direct connection to the switch’s console port and power cycle the switch. Immediately after powering on, press <Ctrl><u> to access the system file menu. ]Select <D> to delete all user-defined configuration files. Press <Q> to boot the switch.
hope this solves your problem
Aug 08, 2009 | Foundry Networks Foundry EdgeIron 2402CF...
PS2 is online when I test the connection, but I can't play online
try setting it for PnP
Don't forget to rank the advice!
http://www.aa1consulting.com
Jul 27, 2009 | NetGear FVS318 Cable/DSL ProSafe VPN...
Need to reset netgear router wpn824v2
Don't tell me you tried to upload the firmware from a wireless connection.
It's probably bricked. You could act stupid and send it back to Netgear, claiming it just died...(it did right?) and in the meanwhile, Staples is selling 624's for $40 this week.
Carl
Jul 05, 2009 | NetGear RangeMax WPN824 Wireless Router
How do i hook my bluetooth to my ps3
After you have connected the headset to the PS3™ system, you can verify that the PS3™ system is receiving voice input from the headset
and that the headset is correctly playing output.
To test and configure your headset
In your PS3™ system’s home menu, go to [Settings] > [Accessory Settings] > [Audio Device Settings].
After you pair a Bluetooth® device with the PS3™ system, the Bluetooth® device becomes the default for both input and output audio. If the
headset is working correctly, you can hear your voice loopback in the headset. The audio input bar will indicate your voice level.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
