Question about LG Xnote RD400
I upgrade 2gb ddr2 667 ram could not display - LG Xnote RD400
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Aug 23, 2013 | HP Pavilion ze2000 Notebook
Can I add more RAM to my Averatec All-In=One A2?
Hey Nella Coffey
Unfortunately, more RAM cannot be installed due the limit of Slots available. However, you may be able to upgrade the current RAM modules and replace them. It appears it has 2048mb (2GB) of RAM which is possible split into two 1GB sticks. You "may" be able to upgrade to 4GB (split into two 2GB sticks). This is the current set up for the computer: 2048MB (4096MB max) SDRAM ' Memory Slots available for Upgrade: 0 ' Maximum RAM per available slot: 2048MB
Good Luck
Jul 29, 2012 | Averatec AllInOne A2 Desktop
Fujitsu v700 4 gb memory will not boot
You don't say if the Notebook is 32 or 64 bit.
If its 32 you may have a problem uprating the RAM more than be handled.
Aug 03, 2017 | Fujitsu LifeBook V700 Notebook 15.4...
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
I have hp dv-1000 laptop with 256 ram, which i wud like to upgrade to maximum.so how many GB ram i can go for and what wud be the price.?Can i go for 4GB ram?
You can upgrade to 2Gb ram. I dont think your notebook will support 4Gb ram. A 2Gb Transcend ram will cost you around 1500 bucks INR
Sep 01, 2009 | HP Pavilion dv1000 Notebook
How much ram does asrock p4i45gv support?what is the maximum ram capacity i can upgrade to???
- 2 x DDR slots, DDR333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Jul 07, 2009 | Asrock P4I45GV R5 Motherboard
Can i upgrade my MT3705 to 4GB RAM?
If you get rid of Vista and put in 2gb of Ram your Laptop will not need 4 gb of ram.  You need to get it will not support double sided or ECC this is why you can not have 4gb you need 2GB kit (1GBx2), 200-pin SODIMM, DDR2 PC2-5300 memory module
Jun 12, 2008 | Gateway MT3705 Notebook
LG Xnote RD400 Logo
19 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
