Question about EdgeStar Heating & Cooling
Climate control panel unit
Hi. I have a 2010 Edgestar AP12000S portable A/C unit. The Edgestar phone tech rep told me that the "power board" has probably gone bad. When turning the unit on for the first time this summer, I heard a beep but saw no lights on the top control panel. Reset the plug & tried again...got lights on the control panel for approximately 30 seconds but the unit did not turn on. All other attempts to power up the unit have failed...no lights, no power -- only an occasional single "beep." I've removed the back cover of the unit and would like to replace the bad "power panel" - any suggestions? Thanks, Bob.
    Top Expert:
  • EdgeStar Master
  • 8,514 Answers
If voltage to board bad board
Posted on Mar 24, 2018
SOURCE: oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Posted on Sep 30, 2007
SOURCE: Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Posted on Oct 02, 2008
  • 400 Answers
SOURCE: We have a Vulcan Bonaire evaporative cooling unit
The problem may be with the drainpump not functioning properly. They sometimes clog up with scale. Easy to remove and clean by opening up the unit. Some units also have an alarm function when the cell pads need replacing. Again this one would be able to see visually. They simply slide out, you would have to locate a supplier and just buy four cellpads.
Posted on Mar 04, 2009
asjsa
  • 36 Answers
SOURCE: Liquid spilled on laptop computer keyboard
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
82
Posted on Mar 13, 2009
freetek
  • 5568 Answers
SOURCE: No power on Westinghouse LTV-46w1 Television
This kind of failure is very common; that is why I suggest that one should keep the old CRT TV, buy a converter and put them both in the garage or basement so they are handy when our s*e*x*y new sets go belly up.
With fair confidence I can say that the main power supply has failed.
If you want to try this on your own, it only will require the removal of a few screws and a flashlight.
- Unplug the set overnight. - Remove the rear housing  - Use some logic and these tips; look for a separate board with larger than average parts on it and seems closer to the power cord than others. This will be the power supply.
Check the board over for something that looks like a part number and record it. If you find more than one, one of them will be the bare board number, the second (sometimes on a sticker instead of printed directly on the board) should be the part number for the assembly.
Search for the Westinghouse service company nearest you and call them with this info. Ask if they repair these or just sell new ones. If it is the latter, don't pitch the old one, continue to look for a repair service that will take it on after you have the new one in place and can watch your favorites again. The new supply will likely cost between $90 - $150 and with a little common sense, most anyone can remove and replace these in the set. Expect any repair to cost about the same as a new supply; US technical labor costs more than Chinese assembly labor.
These supplies can be as reliable as the primitive older type but companies refuse to use the high-grade components necessary to give them a long life so they fail much sooner than the old, less efficient kind known as 'linear' supplies.
Posted on Mar 22, 2009
Edgestar wine cooler blowing fuse on the left side circuit board
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Mar 25, 2014 | EdgeStar ES TWR325ESS-32 Bottle Dual Zone...
How do I replace the exhaust fan on edgestart portable airconditioner AP12000S
I have an Edgestar AP 420HS and I need to replace the horizontal hamster wheel type exhaust fan that is rattling badly. I removed all screws and still can not remove the back of the unit. Two screws required a 7 inch long hex screw driver. Please post any information that may be helpful.
Aug 13, 2012 | EdgeStar Portable Air Conditioner Heater
How do I change the pc drum on a di 2010?
Hi to replace the drum on the machine you will need to do the following
select the tech rep mode then counter-pm-pc life press the clear key to clear the counter value turn off the power. Open the right side door slide out the drum unit from the left and right side of the unit remove the four silve screws two at each end now seperate the top part from the bottom part the top part holds the drum and the bottom part is the developer unit and holds the developer
you can buy the top part as an assembly then reinstall the new drum to the bottom developer unit put back the four silver screws you took out earlier and then put the unit back into the machine
You should replace the developer if you are replacing the drum at the same time now the unit is back in the machine turn on the power select tech rep mode then function f8 and then press the start key ONLY PRESS F8 if you replace the developer
you will also need to go into tech rep mode counter pm developer press the clear key to clear the value
turn off machine wait ten seconds turn back on this resets the counter
Tech rep is normally user counter then stop 00stop 0 1 press one after the other
Jan 11, 2011 | Minolta DI-2010F Copier
EDGESTAR PORTABLE FREEZER IS NOT COOLING. Replaced three components. power to power supply but no power coming out to thermostat control
Usually the power cord connects to a terminal block.Follow the cord to the terminal block and see if it is pulled loose
Sep 15, 2010 | EdgeStar 1.4 cu. ft. Chest Freezer FP430
Control board, fan and compressor all rep[laced with new ones. freezer side cools 45- 50 degrees, cooler side 55-60 degrees. Now I am told that I need an inverter to make it work. I think tha my tech does...
Most likely he had no clue what he was doing that is a complicated ref to work on considering it has 2 control boards and inverator board and dc powered evap fan.
Aug 22, 2010 | Whirlpool Refrigerators
The bottom plastic panel of my EdgeStar AP 14000 HS is cracked and leaks water. It is still under parts warranty so I expect a free replacement panel to be provided by EdgeStar. Question: how do I install...
I just replaced this pan on my unit. I have to admit it was more of an issue than I predicted. You need to remove the screws from the back cover of the unit. Then you can swing the back cover up like a hinge until it is sitting upside down on top of the front cover. Be careful not to damage the wires connecting to the circuit board. You can then remove the circuit board. After the circuit board is removed, you can remove the screws and the front cover. (note, you will have to spread the front cover to get the tabs on the center mounting locations to pop over the frame. After the front cover is removed you will see several things mounted to the base. I removed all of the fastners including the large nuts holding the compressor down. Then with some help,from a second person I lifted the unit and pulled the base away. I had to remove the yellow ground wires from the compressor in order to remove main unit. you will notice now that there are a few pieces attached to the base. I removed each piece and reinstalled it on the new base. then I assembled the entire unit in reverse.
Jul 10, 2010 | EdgeStar AP14000HS Portable Air...
Heating & Cooling Logo
51 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
