Question about Fedders Heating & Cooling
Fedders A3Q06F2D - Fedders Heating & Cooling
I have a Fedders dehumidifier Model A7DH45B2A REV-A. The nipple on the float broke off. Where can I buy a float? Do you have one? How much is it?
Although Fedders, as you knew it is no longer in business, some parts are still available.
Here is a link, with an explodes view of your model's parts.Locate th epart you need and then enter the part number, to see if it's still available. FYI Maytag Dehumidifier parts are interchangeable with Fedders. Fedders made the units for Maytag.
http://www.appliancefactoryparts.com/dehumidifiers/fedders/a7dh45b2a.html
I hope this helps you find what you need.
Jun 19, 2011 | Fedders A7DH45B2A Dehumidifier
Coil is freezing up.rusted coil sensor bracket. i need a new freeze switch sensor for the front coil. i guess it turns the compressor on and off so the coil doesn't freeze solid. can't find the...
Buck, as you seem to be aware, Fedders no longer exist as the Fedders you may have been familiar with 8 years ago. Finding manuals and parts, is like looking for a needle in a hay stack. However, the new company Airwell-Fedders may be able to help you. There Customer Support Dept 866-829-2440, is who you need to contact.
There is one other possible source, as some parts are interchangeable. Appliance Factory Parts
http://www.appliancefactoryparts.com/airconditioners/fedders/ does carry some of the older Fedders Parts, as well as Maytag. So, that may be worth a try.
Hope this helps you find the parts you need. Good luck and please let me know how it worked out for you. Thanks.
Jun 11, 2011 | Fedders A7DH45B2A Dehumidifier
Living in Burlinjgton Ontario Canada. Looking for owners manual. How can I get one?
Henry, unfortunately Fedders as you knew them is now out of business, A company by the name or Airwell bought parts and manufacturing and it's now call Airwell-Fedders. You particular model is no longer available. However, if you contact Airwell-Fedders Customer Service 866-829-2440 or email them customerservice@airwell-fedders.com they should be able to help you with the manual.
Good luck. I hope this helped you.
May 24, 2011 | Fedders SFPEB08F2B Air Conditioner
HOW DO I GET MY FEDDERS AIR CONDITIONER BACK TO FARENHEIGHT
Problem with Fedders (A6R12F2A) Air Conditioner
FARENHEIGHT
Nelvie: silverslipper@candw.ky
Aug 20, 2010 | Fedders AED24E7F Wall/Window Air...
Fedders PTAC/PTHP Condenser Fan
What is your model number, maybe we can help.
Greg
Aug 07, 2008 | Fedders AED24E7F Wall/Window Air...
Heating & Cooling Logo
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
