Question about Ricoh Aficio 2238C Color Copier Printer
I have an error code "Incompatible USB device has been connected"
    New Friend:
I have a Recoh MP C5201. I was reading USB pen drive before but now when you slot in ant usb pen drive,it displays that an incompatible usb has been installed.USB has been enabled but can not read it.How can I solve this problem. Regards, Bentil
Posted on Jul 18, 2014
How should i fix the app error 523 ?
OK. First start off with the battery out of the phone and the usb cable unplugged. Next open the Desktop Manager, then go into Application Loader. When you get to the part where it asks for the connection type just plug in the usb cable (still leaving the battery out). If the connection changes to usb<pin> or usb<unknown>, hit Next. Keep going through the wizard till you're on the last step, before you hit Install. Now put the battery in and see if the loadin
App Error 523 usually happens after loading incompatible 3rd party software. Did you load anything lately? You should be able to connect to the device while it's rebooting (spinning hourglass) with application loader and remove the offending 3rd party application. g operation completes.
May 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
I own a Canon Pixma MP600. Working on Windows XP Pro, version 2002, SP3. Have used printer for 1.5 years with no problems. Now, I turn it on and an error message (no number given) appears on the printer...
You can re-install the Driver using the Installation Disc shipped with the Computer. You can uninstall it from the Add Remove Programs Window.
To access Add Remove Programs Window, please press Windows+R key at the same time..
Then type appwiz.cpl and press Enter key to get the Add Remove Programs Window..
The uninstall the Printer.
Re-install using the installation Disc after a restart..
Please let me know if I was Helpful
Mar 05, 2011 | Office Equipment & Supplies
My audio driver is not working (error 10)
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
I suggest trying an update, or if you just updated it roll back the driver.
Mar 03, 2011 | Acer Realtek AC'97 Audio Driver XP W2K W98...
App error 523 on bb curve
OK. First start off with the battery out of the phone and the usb cable unplugged. Next open the Desktop Manager, then go into Application Loader. When you get to the part where it asks for the connection type just plug in the usb cable (still leaving the battery out). If the connection changes to usb<pin> or usb<unknown>, hit Next. Keep going through the wizard till you're on the last step, before you hit Install. Now put the battery in and see if the loading operation completes.
Jun 01, 2010 | RIM BlackBerry Curve 8520 Smartphone
The device may be incompatible. Remove the device
Hi There,
Check the device connected to the Direct Print Port. Printing photos directly is possible with a PictBridge compliant device or the optional Bluetooth Unit BU-30.
A communication time out occurs if an operation takes too long or if it takes too much time to send data. This may cancel printing. In such cases, disconnect and reconnect the USB cable. When printing from a PictBridge compliant device, depending on the model or brand of your device, you may have to select a PictBridge compliant print mode on the device before connecting it to the machine. You may also have to turn on your device or select Play mode manually after connecting the device to the machine. Perform necessary operations before connecting your device referring to its instruction manual. If the error is still not resolved, check if you can print another photograph.
Mar 07, 2010 | Canon PIXMA MP600 all-In-One InkJet...
The usb connectors show as 1.1 usb not 2.0 and one set of them does not correctly identify the usb device. The same one, when my hub is connected shows an error pertaining to not enough voltage to run...
What is the USB device as the mobo specs state that they are all 2.0. Sounds like incompatible USB device.
Ensure you have latest SP installed on whatever Win version you have also.
Dec 04, 2009 | ASUS P5NSLI (0610839134670) Motherboard
Jvc gz-mg130 and jvc cu-vd20
I had this problem with the GZ-MG505AA (connecting to WinXP SP3). I tried a different USB cable and it worked first time.
Not sure what is different about the cables (the original cable worked fine with my WM 6 mobile phone).
Dec 27, 2007 | JVC Video Cameras
Pioneer D3 navigation - Bluetooth connection
on pioneer head units u can only use apple ipod and nano and up....if its a usb cord then it should work but if it is only the hook up off the cd player nano and up and only apple ipods
Dec 16, 2007 | Pioneer Car Audio & Video
Ricoh Aficio 2238C Color Copier Printer Logo
1,799 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
