Ikasu av820 ,when i try to record it says cannot record source may be protected , it didnt do this untill i reset windows up from scratch
  • petehumphries Aug 02, 2013
    I have been asked to add more detail about my query, I have used the ikasu ripping usb dongle for some years with no problem , I reset my pc up to factory settings with the same windows system , since doing this i have tried my av820 , it all works , good picture and sound but when i try to record it says cannot record , source may be protected . I have the pc set up exactly as it was before reset , i cannot understand why it now stops me from recording with the av820.
Forgot password on ICRAIG model cmp801 windows 10 tablet.
You can use a installation media to perform a factory reset:
http://www.makeuseof.com/tag/4-ways-reset-windows-10-reinstall-scratch/
If you lost just the local account password, there are many ways to reset it:
http://www.top-password.com/knowledge/reset-windows-10-password-without-reset-disk.html
I recommend you backup personal files and software licenses before doing a factory reset.
Mar 05, 2017 | Cell Phones
Can any1 help with my ikasu tv remote code
http://www.rockabilly.net/files/manuals/URC-7740.pdf
Download the manual and if your model is not listed follow the section called search method and the set will do it for you.
Let me know if this helps.
May 02, 2014 | Supersonic Televison & Video
Dvd says cannot record copy protected movie how to fix ?
Depends what you are trying to record? Some TV stations have protection built in so you cannot record. If you are trying to copy a video from VHS to DVD and it's a commercial movie etc then it won't.
You can get a "box" that will get rid of copy protection signals, but only from outside the unit sources. Internal dub to dub protected sources cannot be copied.
Feb 04, 2013 | Samsung DVD-VR357 Tunerless DVD Recorder...
I have connected my phillips cdr785 recorder the proper way to record from an external source and I get the message "start source" on the cdr side when trying to record. And it never starts...
If you're recording an analog source the recorder won't automatically start. You have to start it in sync with the playback.
If you're trying a synchronized digital recording...
Page 28 of the manual says
Start playback on the selected source.
The CD recorder starts to record simultaneously and recording in progress is shown. The remaining recording time left of the CDR(W) is displayed.
Note: If you start playback on the selected source within a track, recording starts at the beginning of the next track or after 2.7 seconds of silence in analogue recordings.
Mar 05, 2011 | Philips CDR785 3-Disc CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
My DVD recorder LG RH1858 isn't recording properly. It shows the message "record blocking sidnal are detected". Please inform.
Unfortunately, your recorder is picking up a signal in the broadcast that copy-protects the show. The recorder is programmed to forbid copying of protected material. Depending on the source of the copy-protection, you may be able to block out the copy protection signal with a hardware filter. One example of these would be the Sima CT-2 that is placed between the S-out of the receiver and the S-in of the recorder.
I hope this helps.
(One common sources with this issue: a DVR that passes on the copy protection to an attached DVD recorder. Particularly some of the new Satellite/Cable receivers with built-in DVRs. The non-DVR models of the products usually filter out the copy-protection.)
Mar 29, 2010 | LG RH177 DVD Recorder/HDD Recorder
Need pin no. to reset Ikasu KVT910A factory settings
Try default PIN of 136852 - good luck!!!
Jan 30, 2010 | Televison & Video
I wont to find vista drivers for a 2GB MP4 player from IKASU
depends how old all the new computers are very selective on wat they connect with your mp3 player could be obselete
Dec 08, 2009 | Audio Players & Recorders
Screen says cant record copy protected movie
Is this a new problem or has it always been like this? The unit will throw that error message if there's a copy protection flag on the broadcast source.
To make matters worse, there are three flags a broadcaster can set. Copy Always, Copy Once, and Copy Never.
Copy Always and Copy Never are pretty self-explanatory but the Copy Once flag with this unit only works with certain media, namely DVD-RAM and DVD-RW in VR mode with CPRM (Content Protection for Recordable Media.
Copy Always flag should work with all media. I don't know of any easy way to figure out which broadcasts have which flag but try changing your media and recording mode first.
P.S. You may also want to reset to factory default settings by pressing FF and RW together on the player. Also make sure you're running the latest firmware.
Good Luck!
Feb 02, 2009 | Samsung DVD-VR357
Computers & Internet Logo
David Payne
David Payne
