Question about Waterway Pool & Spa
WHAT SIZE RUN CAPACITOR DO i NEED FOR A SD-20-2N11CD?
I HAVE 1.5 TON SPLIT A/C WHAT SIZE OF RUNNING CAPACITOR WILL WORK IN COMPRESSOR?
the capacitor that is required is the same size as what is fitted
it will read as voltage and uf number
best have a ac technician check it out as it may not be the capacitor but the power board
some ac units have a capacitor that is in effect two capacitors in one to run the compressor and the cooling fan as well
best get the technician in as it could save a lot of money in the long run
Aug 08, 2015 | Dayton Permanent Split Capacitor Motor Fan
What size run capacitor should I use for wolf electric lawnmower 220v with. Rpm 2850 and. 50Hz
Sounds like a flux capacitor. You probably need one sized at 1.21 gigawatts.
Dec 26, 2014 | Electric Garden
I have a intertherm e2eb-012ha. I need to know what size run cap to use. . The plastic coating has been melted so I can not see the run cap info.
It appears you may already have located your problem, the capacitors are very coming to burn out, if a motor will run after you spin by hand, mmore times than not the capacitor is the problem. The name tag on the equipment itself sometimes has the capacitor size and the motor nameplate usually does as well. you can call Nordyne support at 18004224328 and with your Intertherm Model number they can give you the correct capacitor size, which you can purchase at any HVAC supply house. If I had to guess, I would say you need a 5 mfd capacitor based on the blower size. but call them and verify. Also, most all supply houses that sell that capacitor can run the Intertherm numbers and see the correct size as well.
Jan 06, 2013 | Heating & Cooling
Failed capacitor on clarke SE 14 compessor
On electric motors with two capacitors, one is a start capacitor, the other is a run capacitor. Start capicitors have plastic cases and are rated from 200mf to 400mf and higher depending on the size of the motor. Run capacitors are in the 20mf to 40mf range and usually have metal cases. If you have an electric motor service center in the area they can recommend what size you should use for the size (HP) motor you have.
Oct 31, 2012 | Clarke Air Tools & Compressors
My sd card is saying blank or unsupportedfiles how do I fix that so I can take a pic
CHECK THE SIZE OF THE SD MEMORY AND MUCH IT WITH THE FACTOLRY LABLED SIZE.
IF YOU SEE YOU HAVE USED THE SPACE BUT YOU DONT SEE ANY FILE INSIDE
TRY THIS
GOTO RUN TYPE CMD
TYPE NAME OF YOUR SD
EG
'F:' WITH OUT THE QOUT AND TYPE attrib -r -a -s -h and enter your hiden files will beshown
to format your sd card us sd card formater
chirs
Aug 23, 2010 | HTC Cell Phones
Ruud UAFD 03 JAS AIR CONDITIONER
THE MFD SHOULD BE ON THE SIDE OF THE OLD CAPACITOR IF NOT THE MOTOR IS RATED FOR 3 MFD THATS WHAT YOU NEED
Aug 18, 2009 | Heating & Cooling
What size SD do I need?
you should be safe with a 4GB SD card,(maybe 8GB ?) as it is a fairly new camera, goto 7dayshop.co.uk for a idea of prices
Jun 13, 2009 | Video Cameras
Ruud heat pump capacitor size
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
Jun 26, 2008 | Heating & Cooling
What is the maximum amount of SD/MMC memory on e330
In my opinion there is no any limitation. I am pretty sure that you can use 1GB SD Card without any problems. Only thing that can happen is that access to your data can be a little bit slower.
Sep 11, 2005 | Toshiba e330 Pocket PC
Pool & Spa Logo
62 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
