I am the type of person that can never be too sure or too perfect. This extends to my covered call strategy and it can really drive me crazy. So, with that said, I am looking for a screener that will not only help me find covered calls, but also write calls. Ideally, it would be affordable and free of errors, so please help me out!
jANE (posted to cars/trucks)
An engine fully turned up to the max
produces, the maximum C02, carbon. (perfect combustion)
only smaller or lighter cars and tiny engines are low carbon.
electric cars only move the carbon from your car
and moves it to someone elses neighbor hood, in most cases.
drive less
bike more.
walking even has carbon,,,humans emit carbon,so....
Run a Diagnostic test on the vehicle computer,
code(s) stored in the vehicles PCM/ECM, will let us know more about the vehicles symptoms.
AutoZone will connect a scanner for free.
Post back with the codes
I have run into the drive shaft seal and or dust cover drying out causing a squeal. Just pull the drive shaft and put a light coating of grease on the seal and dust boot.
Is this an internal CD-ROM drive? I don't know if there are extender cables available. I would just look for the correct type, but longer. I'm pretty sure there are 24" or 36" cables available.
if the car was fine before you killed the battery and now the tranny is shifting crazy. it has forgotten its adaptive strategies and is trying to re learn, if its always been like that even before the battery sounds like a valve body issue
Sounds Like the Starter RELAY is Bad After Exhausting All other Test, Go For The RELAY
A SURE-SHOT way Is to Jumper Wire From Battery to (STARTER SIDE) of Relay if starter Works then Its the Starter Relay if NOT>>Then Its the STARTER<) Relay Instruction Below. STARTER Instructions Very Bottom REMOVAL WARNING: WHEN PERFORMING MAINTENANCE ON THE STARTING SYSTEM BE AWARE THAT HEAVY GAUGE LEADS ARE CONNECTED DIRECTLY TO THE BATTERY. MAKE SURE PROTECTIVE CAPS ARE IN PLACE.
Disconnect the battery ground cable.
Disconnect the starter motor solenoid relay switch wiring.
Remove the protective cover.
Disconnect the push-on electrical connector.
Remove the nuts.
Remove the cable.
Remove the starter motor solenoid relay switch.
Remove the engine sensor/generator wires.
Remove the bolts and ground wire.
INSTALLATION
Follow the removal procedure in reverse order NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
REMOVAL
WARNING: WHEN PERFORMING MAINTENANCE ON THE STARTING SYSTEM BE AWARE THAT HEAVY GAUGE LEADS ARE CONNECTED DIRECTLY TO THE BATTERY. MAKE SURE PROTECTIVE CAPS ARE IN PLACE WHEN MAINTENANCE IS COMPLETED.
Disconnect the wires.Remove the nut and the starter ground cable
Remove the bolt and the starter motor.
Follow the removal procedure in reverse order. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
It sounds like the DVD burner does not have a "write strategy" for the type of disc you are using. This results in the burner and the software having an endless argument about how to go about the burn! You can either use another brand of disc more compatible with your burner or go to the DVD burner's manufacturer's website and check for "Firmware" updates. The firmware is the software within the drive that establishes the write strategy for each type of disc and these are often updated. If you do update the firmware then be sure to read the instructions on the manufacturers website carefully and follow them EXACTLY.
in my opinion, generally not. most extended warranties do not cover user "abuse" or "wear-and tear", so any issues of this type will probably not be covered regardless (check the fine print to be sure). a refrigerator doesn't have moving parts like a washer or dryer does, so failure of any part on a new refrigerator within the original warranty period plus 4 additional years is unlikely. please keep in mind that purchase of extended warranties is an extremely personal choice. there are many factors that should go into the decision, including (but of course, not limited to) how much risk you are personally comfortable with, how much the refrigerator is worth, and if you would be able to afford an out-of-pocket repair. good luck!
