Question about NEC LT155 OWIZ136606464101
Cooling fan replacement - NEC LT155 OWIZ136606464101
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Fans USD30
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Posted on Aug 25, 2016
Hola buenas tardes tengo un problema con mi ford escape 2009 motor 3.0 que las ventiladoras de enfriamiento se me an quedado directac y no hacen sus ciclos de parar cuando el motor esta frio si no que...
Necesitas un sensor de enfriamiento del ventilador. Est? ubicado en el radiador.
You need a Fan Cooling Sensor. It is located in the radiator.
2005 Ford Escape radiator cooling fan repair. - YouTube
? 3:19
https://www.youtube.com/watch?v=3Sk5g4PGVWs
Sep 24, 2014 - Uploaded by hufhuffy
2005 Ford Escape cooling fan problems ,cooling temp sensor auxiliary fan control unit ,radiator fan switch ...
2009 Ford Escape Hybrid radiator cooling fan - YouTube
? 1:42
https://www.youtube.com/watch?v=tRdrV825xak
Mar 8, 2017 - Uploaded by stevenofpa
00243 2009 Ford Escape Hybrid radiator cooling fan - This video shows the engine cooling fan radiator fan ...
2008 Ford Escape Cooling Fans: Both Aux and Main Cooling Fans ...
https://www.2carpros.com/questions/2008-ford-escape-cooling-fans Jun 17, 2014 - I have replaced the Main cooling fan relay but didn't help. Not sure if there is ... 2002 Ford Escape Coolant Overflow Bottle Replacement.
2009 Ford Escape Cooling Sensors, Switches & Relays - CARiD.com
https://www.carid.com > ... > Ford > Escape Results 1 - 21 of 21 - Ford Escape Replacement Engine Cooling Parts - 2009 ... Ford Escape 2009, Coolant Temperature Sensor Connector by Standard®. 2009 ford escape replace cooling fan sensor Google Search
Oct 28, 2017 | 2003 Ford Escape
927.21 lexmark error
A 927.17 is a LVPS cooling fan failure: LVPS cooling fan is obstructed or has failed.
1. Check for cooling fan obstructions.
2. Check the connections on the main cooling fan.
3. Replace the LVPS cooling fan.
Nov 12, 2012 | Lexmark "x654de multifunction monochrome...
Fan comes on when switch ignition on instead of when hot Tazz
If the fan not turning on when car engine getting hot,then car will notice overheating.Click this link below for troubleshooting:---http://technoanswers.blogspot.in/2012/02/car-running-hot.html--------To know how engine cooling system works ,click the link below :----Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
------------How to Replace Engine cooling Fan:-- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
-----------Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
---------Where Is Radiator Fan relay and Fuse Located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radiator-fan-relay-and-fuse.html
This will help.
Thanks.
Feb 09, 2012 | Cars & Trucks
My radiator fan is not working
For radiator replacement procedure and radiator problem troubleshooting. I suggest you to click the link below and follow the detailed procedure :-----
How to Replace Engine cooling Fan on car? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
Engine makes noise and Cooling Fan belt Breaks? http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Cooling fan relays location? http://technoanswers.blogspot.in/2012/02/cooling-fan-relays-location-on-1998.html----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
How to replace radiator Cooling Fan?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
cooling fan not working http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html----------- Fuel pump relay and cooling fan relay troubleshooting? http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
How to replace Radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
HOW TO REPLACE AN UPPER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
HOW TO REPLACE A LOWER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
How to replace Radiator on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-acura-car.html
How to flush cars radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-flush-cars-radiator.html
HOW TO PRESSURE TEST A RADIATOR AND CAP
http://schematicsdiagram.blogspot.com/2011/07/how-to-pressure-test-radiator-and-cap.html
HOW TO REPLACE A RADIATOR
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator.html
HOW TO REPLACE A RADIATOR SUPPORT
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator-support.html
This details will help.
Thanks.
Feb 01, 2012 | 1997 Mercury Cougar XR7
Radiator fan motor does not run
1. check the cooling fan fuses
2. supply battery voltage directly to the fan assembly plug
a. if fan is good
locate and test/replace cooling fan relay
b. if bad
replace cooling fan assembly
if still is not working check continuity cooling fan system circuit/wiring
Aug 19, 2010 | 1999 Nissan Quest
Electric Radiator Fan Does Not Come On
Chevy dealer says will not come on until temperature reaches 219 f
May 16, 2010 | 2007 Chevrolet Silverado 1500 2WD
Where is the switch that cuts on the cooling fans on a 2000 grand am with a 3.4 engine
The computer turns on the fan. Based on sensors from the motor.
DTC P0480 - COOLING FAN CIRCUIT
Circuit Description
The cooling fan is controlled by PCM through the fan relay based on inputs from ECT sensor, IAT sensor, A/C selector switch, A/C refrigerant pressure switch and vehicle speed sensor. PCM controls cooling fan by grounding cooling fan control circuit which turns on cooling fan relay.
The fan relay will be commanded on when ECT reaches 223°F (106°C) or greater, A/C is requested or vehicle speed is less than 38 MPH. Cooling fan relay will also be commanded on regardless of vehicle speed when a DTC is set requesting cooling fan to be on, ECT is 304°F (151°C) or greater, or A/C refrigerant pressure is high. Cooling fan may also be commanded on when engine is not running, on certain conditions.
Conditions for setting DTC:
Battery voltage greater than 9.5 volts.
Cooling fan fault line detects a malfunction for 6 seconds.
1. Check cooling system. Ensure coolant level and belt tension are correct. Adjust/repair as necessary. After repairs, go to step 23). If no adjustment or repairs were required, go to next step.
2. Turn ignition on, with engine off. Using scan tool, check if cooling fan is operating with ECT at less than 209°F (98°C). If cooling fan is off, go to next step. If cooling fan is on, go to step 4).
3. Command cooling fan relay on. If cooling fan operates, go to step 23). If cooling fan does not operate, go to step 5).
4. Turn ignition off. Disconnect PCM harness connector. If cooling fan turns off, go to step 23). If cooling fan does not turn off, go to step 6).
5. Disconnect cooling fan relay harness connector. Using a test light connected to ground, probe battery feed circuits in relay harness connector. If test light illuminates on both terminals, go to step 7). If test light does not illuminate on both terminals, go to step icon_cool.gif.
6. Disconnect cooling fan relay harness connector. With test light connected to ground, probe battery feed circuit in relay harness connector. If test light illuminates, go to step 9). If test light does not illuminate, go to step 10).
7. Connect a jumper wire between cooling fan relay battery feed and cooling fan battery feed circuit. If cooling fan operates, go to step 11). If cooling fan does not operate, go to step 12).
8. Repair open in battery feed circuit. After repairs, go to step 23).
9. Repair short to voltage in cooling fan battery feed circuit. After repairs, go to step 23).
10. Connect test light battery voltage and probe cooling fan control circuit. If test light illuminates, go to step 13). If test light does not illuminate, go to step 21).
11. Connect test light to battery voltage and probe cooling fan control circuit. Using scan tool, command cooling fan on. If test light illuminates, go to step 14). If test light does not illuminate, go to step 15).
12. With jumper wire still connected, disconnect cooling fan harness connector. Using test light connected to ground, probe cooling fan battery feed circuit. If test light illuminates, go to step 16). If test light does not illuminate, go to step 17).
13. Repair short to ground in cooling fan control circuit. After repairs, go to step 23).
14. Check terminals to cooling fan relay. Repair as necessary. After repairs, go to step 23). If terminals are okay, go to step 21).
15. Check cooling fan control circuit for open or poor connection. Repair as necessary. After repairs, go to step 23). If circuit or connection is okay, go to step 22).
16. Connect test light to battery voltage and probe cooling fan ground circuit. If test light illuminates, go to step 1icon_cool.gif. If test light does not illuminate, go to step 19).
17. Repair open or poor connection in cooling fan ignition feed circuit. After repairs, go to step 23).
18. Check for poor connections at cooling fan harness connector. Repair as necessary. After repairs, go to step 23). If connections are okay, go to step 20).
19. Repair open or poor connection in cooling fan ground circuit. After repairs, go to step 23).
20. Replace cooling fan motor. After replacing cooling and motor, go step 23).
21. Replace cooling fan relay. After replacing relay, go to step 23).
22. Replace PCM. Program replacement PCM using required equipment. After replacing PCM, go to next step.
23. Turn ignition on, with engine off. Command cooling fan on. If cooling fan operates, system is okay. If cooling fan does not operate, repeat step 1).
May 16, 2010 | 2000 Pontiac Grand Am GT
I replace the fan clutch and i still have the code p1481 what does that mean? 2002 chevrolet Trailblazer 4.2 Thanks You! Arthur Tyler
TSB#05-06-02-012B: Service Engine Soon (SES) or Check Engine Light On, DTC P0480, P0526/P1481/P1484 Set (Replace Engine Cooling Fan Wiring Harness) - (Oct 19, 2006)
Subject:
DTC P0480/P0526/P1481/P1484 Set (Replace Engine Cooling Fan Wiring Harness)
Condition
Some customers may comment that the Service Engine Soon (SES) or Check Engine light is illuminated. This condition may be intermittent and upon investigation, the technician may find either DTC P0480, P0526, P1481 or P1484 set.
Cause
This condition may be caused by the cooling fan harness chaffing against the plastic guide it routes through. This
contact may damage the insulation of the wires enclosed in that harness.
Correction
Replace the engine cooling fan harness using the procedure listed below.
1. Remove the cooling fan. Refer to the Cooling Fan and Shroud Replacement procedure in the Engine Cooling sub-section of SI.
2. Place the cooling fan assembly on a bench.
Disconnect the harness electrical connector from the cooling fan clutch.
3. Remove the harness from the plastic guide while feeding the wires out of the slot.
4. Before installing the new harness, wrap the affected area on the wires with electrical tape to keep the protective sleeve in place. Be sure to keep the tape approximately 25 mm (1 in) away from the connector so the wires can be fed into the slot.
5. Feed the wires into the slot and install the harness to the plastic guide.
6. Connect the harness electrical connector to the cooling fan clutch.
7. Install the cooling fan. Refer to the Cooling Fan and Shroud Replacement procedure in the Engine Cooling sub-section of SI.
Part Number 89024920
Description
Harness Assembly, Engine Cooling Fan Wiring
Thank you for using fixya.
Apr 29, 2010 | 2003 Chevrolet TrailBlazer
The cooling fans stop working
check your sensor that controls the cooling fans.may need to be replaced.
Jan 01, 2010 | 2003 Chevrolet Impala
Noisy fan
You need to replace the fan. Measure the fan you have now and buy one the same diameter. Then remove the old fan and put in the new fan.
May 28, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
NEC LT155 OWIZ136606464101 Logo
51 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
