Rancilio Audrey
Problem for Rancilio Audrey
Leaking steam valve rancilio miss audrey
By i_scharree on Apr 01, 2009
I have a very old rancilio miss audrey that makes very good coffee, however I have a serious problem concerning the steam valve.  How can I disassemble the rancilio audrey steam valve in order to fix a leaking problem. The valve is constantly leaking water during the coffee making process, which causes a diminishing pressure. I think it has to do with a small rubber ring in the valve, but I am not sure how to fix it. Which part of the valve has to be loosened first?
Thanks,
Ilona Scharree from Amsterdam
Best Solution
posted on Apr 02, 2009
Very Helpful)
z34aga
Rank: Guru
Rating: 86%, 28 votes
you should take out the knob first, than you try to disasembke the SHAFT of valve from the valve body, in this types(small espresso coffe machines) usualy producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal vorkery where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine.
ps: notice you only polish the SHAFT , dont let them to short the more than 0.5 mm
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Rancilio Audrey
Questions and Unsolved Problems for Rancilio Audrey
Do you recommend Rancilio Audrey?
Answer
Answer
I need how to instructions for a maxim espresso maker
Answer
i can't figure out how to froth milk using my esspreso and coffie machine
Answer
i have a cp5-1 espresso machine is there a drain switch for the water
Answer
Hi, I was given an old rancilio espresso Machine, I don't know the name of the model. It's mainly... (More)
Answer
Thats the round machine, I'm going to repaint the metal and its a good opportunity to replaced the... (More)
Describe your Coffee and Espresso... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in , MD
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
