Question about Cuisinart DCC-1200 Coffee Maker
On off switch on my Krups espresseria ea8080 is stuck in. Any way to get the front panel off to unstick it?
Machine is dead. Is there a fuse somewhere? Krups Espresseria.
There is no easily replaceable fuse unless you are from somewhere like the UK where they have a fuse in their giant wall plug on the end of the cable. Some of those Espresserias had a switch button fault where part of the button can break and the button will no longer activate the switch.
Apr 27, 2015 | Krups Coffee Makers & Espresso Machines
Error code 5 on Krups ea8080
During the first few seconds of pump running there is zero water flow. Either there really is no flow at all OR the flow meter is not detecting flow for some reason.
Oct 19, 2014 | Krups Cafe Express FMA110 Coffee Maker
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
I need a manual for krups xp 7240, krups xp 7200, krups xp 7230
I have the manual, send an email to me at inouside@hotmail.com and I will reply to you with the manual in pdf format.
Mar 04, 2009 | Krups XP7230 Compact Super Automatic...
Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Sep 27, 2008 | Krups XP7230 Compact Super Automatic...
Krups xp7420 espresseria automatic
am o proare 01 la un espesor krups 7220/7240
May 11, 2008 | Krups Coffee Makers & Espresso Machines
Cuisinart DCC-1200 Coffee Maker Logo
41 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
