Question about Raypak Pool & Spa
Raypak 266A display is blank, heater works fine.
  • cadeldo
    cadeldo Aug 03, 2013
    Display failed after about ten months, Raypak warranty excludes owner installed units (mine). Heater functions fine, am guessing at a display that can 't stand tthe western sun, as the original heaters display failed also. My question, display alone, or circuit board?,
    Top Expert:
  • Raypak Master
  • 8,673 Answers
Need new display
Posted on Apr 27, 2016
3 Suggested Answers
StepehnD
  • 78 Answers
SOURCE: service code ROL
This indicates the flame roll out safety switch is bad. This part is usually mounted right above the burner tray. It is a white ceramic piece with two wiring terminals and an external part that looks like a resistor. This part detects flame/heat coming out from the burner tray. When replacing it, be sure to check for blockage at the burner tray, heat exchanger and the flue if vented with duct work. This is a critical safety device so do not bypass it.
Posted on Jun 19, 2010
  • 990 Answers
SOURCE: hi. i have a raypak 266a just 1 month old and the
First check your pump basket and filter to be sure they are clean.
Posted on Jun 29, 2010
Reset water temp in pool
Up and down arrows on a digital unit will adjust temperature to higher or lower desired temperature.
Potentiometer knob will adjust temp higher or lower by rotating the knob.
My answer is only a guess at the question you are asking - no specifics, too general and too basic.
Jun 02, 2015 | Raypak 266A Digital ASME Natural Gas IID...
How to winterize a raypak pol heater
blow out with air then antifreeze (RV antifreeze red stuff)
Aug 27, 2013 | Raypak 266A Digital Cupro-Nickel Natural...
Nothing happens when I turn it on
if voltage to unit check transformer for voltage if ok bad display if display check safety circuit
Jul 30, 2012 | Raypak 266A Digital ASME Natural Gas IID...
HL1 error water not heating
check gas pressure if ok check manual bypass see if spring is ok if broken or stuck closed that if ok see if unit is turning off check gas pressure to see if running out of gas and turning off then gas line filling up and turning on again
May 21, 2012 | Raypak 266A Digital ASME Natural Gas IID...
The lcd on my raypak 266a keeps flashing REM OFF and then shows the water temperature with the word OFF
is connected to control take and turn off T stat on remote and turn remote off then you can operate manually if you want remote then activate T stat to remote
May 14, 2012 | Raypak 266K BTU Digital Residential...
Service code ROL raypak pool heaters p-r-266a-en-c
May 29, 2010 | Raypak 130,000 BTU Propane Gas Pool...
Pool & Spa Logo
114 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
