Question about Mitsubishi VS-5043 50" Rear Projection Television
HOOK UP INFORMATION
I REC'D A MITSUBISHI BIG SCREEN MODEL # VS5051. I NEED TO KNOW WHAT GETS HOOKED UP WHERE ON THE BACK OF THE TV. I HOOKED UP THE CABLE FROM THE WALL TO ANTENNA OUTLET #1, I GET SOUND TO COME OUT OF SOME CHANNELS, HOWEVER, THE CHANNELS DO NOT COME IN CLEAR. DO YOU KNOW IF I NEED TO HOOK ANYTHING ELSE UP TO THE BACK OF TV? THANKS..
  • cdcindy Sep 14, 2007
    Thank you very much. I will let you know. I am going to try right now.
    Genius:
  • 1,153 Answers
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Posted on Sep 14, 2007
SOURCE:
I do not know how to hook it up to Directv receiver or to my DVD
Hello Barbara,
I'm Joe, thank you very much for choosing FixYa for your technical support needs.
I would be pleased to provide whatever assistance you need with hooking up your Direct TV receiver to your TV, or with hooking up your DVD player to your TV.
In order to provide you with the proper specific detailed instructions, could you please COMMENT back here to this page and provide the exact model numbers of your TV, your DVD player, and your Direct TV receiver, since exact connection instructions can vary between different models.
Normally the model numbers are printed on a label on the back panel of each device.
You can use the POST A COMMENT button near the bottom of the screen to post this additional information and I will receive it right away. Then I can proceed to look up and provide you with the appropriate User Manuals for each device and also the necessary instructions to hook them up.
Thank you very much, I look forward to hearing back from you and assisting you further.
Joe.
Oct 04, 2011 | Sharp LC-32D64U LCD TV
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
How to turn on screensaver
Howdy,
This TV does not have a screen saver program this type of TV does not need it. If you have a device hooked to TV such as game Box etc. They have their own screen saver program.
Good Day, Big Irish.
Dec 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
I have an ADC equalizer model # SS-100SL i'm
record out-------equalizer in-------equalizer out------tape in
Mar 01, 2009 | Audio Players & Recorders
Adding vcr & rec to a '93
Please hook up VCR with TV through RF cable and check picture of VCR playback in TV.
Now you can hook DVD player video-audio out in VCR input and can have dvd playback picture in TV via VCR modulator.
If you want to listen sound via receiver then hook audio red-white cable between VCR audio out and receiver audio in terminals.
Let me know exact model numbers of units to help you out more.
Thank you.
Jan 13, 2009 | Televison & Video
Set-up big screen tv
just hook up by color coding. or through HDMI which will be the easiest for you. (if you things support HDMI)
Aug 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No audio from Samsung DTB-H260F
I have a sr605 Onkyo receiver and just hooked it up to a new Mitsubishi 73" and I could not get the picture to work, sound did though. Here is the problem the Onkyo is HDMI 1.3 but TV calls for HDMI 1.3a. There is a big difference between the 2 and the Onkyo will not work with TV. The newer model TV'S say in the manual Category 2 V 1.3a. You need to make sure that all your parts are compatable. It makes a big difference.
Dec 05, 2007 | Mitsubishi HD-6000 DTV Receiver / Video...
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
