Question about Bosch Refrigerators
Hi, my Bosch intelligent frostfree 44 is having problems. When turning it on, it clicks and the fan on the back at the bottom spins but stops after a second, with the led lights on the front flashing at the same time, this repeats for a while. Then when it is eventually on, the fridge doesn't cool and the freezer is about the temperature of a fridge. Ive been looking around and people have been saying its the compressor or compressor relay. Is there any way I can check this in more depth, or is there a part that i can replace to fix this? Could it be the thermostat also? Cheers
4 Suggested Answers
  • 90 Answers
SOURCE: relay clicking, not cooling either side
First of all Give me model# and Serial#.
you will most likely have to replace main control board and evaporator fan motor. They have had a service bulletin out on this problem.
Posted on Jan 17, 2008
asdsad asd
Posted on Mar 22, 2008
imufo2
  • 3773 Answers
SOURCE: Bosch Intelligent Frost Free 44.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 08, 2011
I have a Bosch Intelligent frost Free 44. It keeps on switching on and off the whole time but when I leave open one of the doors, it runs normally. What could the problem be?
faulty thermostat
the thermostat presets on on/off temperature is faulty and when the door is close it is cycling but when the door is open the cycle is not allowed to happen because the on tremp is engaged full time
get a technician in to properly diagnose the fault and quote .
Aug 30, 2016 | Bosch Refrigerators
Bosch intelligent frost free 44
the fridge might have iced up in the coil due to a defrost problem. one way to check it is to leave the fridge off for a few hours and leave the door open. turn the fridge back on after the few hours and see if the performance is any better. Let me know how it goes
May 22, 2014 | Refrigerators
My Bosch Intellignt Frostfree 44 mothaerboard is faulty. Can they be repaired?
If you don't find a way to get the board serviced soon, you should get the part number off the existing board and google it to find a replacement board. I can't imagine the board is terribly difficult to just replace outright.
Jan 08, 2014 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Intelligent Frost Free 44. Freezer on top. Water leaking at bottom of front door. What is the cause of this problem and how can it be fixed.
Leo Ponder
imufo2
Aug 07, 2011 | Bosch KSU49630 Top Freezer Refrigerator
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
there is a drain hole in the freezer dept in the fridge that is blocked This requires removing all the panels etc within the freezer until you get to the main grill at the back This will be iced up so you might have to wait a while or you might be able to chip away at it. You will then see the drain hole concerned at thre bottom Try pocking a thin wire down it or poor hot water over it Its a bit of fiddling around but is not hard to clear Problem solved
Feb 02, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
56 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
