Question about Pets - Others
I bought a dog door for my sliding screen door and the plastic that lets the door swing has broken and it is only 6 months old?
SOURCE: ive broken the plastic slide
I just bought one from Kodak, more expensive with the shipping than those available on ebay. No instructions however, so now I have no clue as to how to replace the cover...
Posted on Apr 30, 2008
SOURCE: swing along castle broken parts need to order My
Go to littletikes.com. They have a seciton to choose outdoor products and you can drill down to the swing and slide castle. All the replacement parts are available there.
Posted on Mar 06, 2009
  • 5 Answers
SOURCE: Crib slide track is broken
I would contact the manufacturer and they should have replacement parts. If it is a storkcraft, then go to Storkcraft.com and go to their parts page.
Posted on Apr 20, 2009
jharwell668
  • 640 Answers
SOURCE: a cracked plastic slide on my daughter's swing set
You can buy a new plastic slide from a company that sells swing sets, but the slide is probably going to cost more than a whole new swing set. The slides can be pricy when purchased separately. You might want to consider upgrading and going with a new, sturdier swing set. As far as I know, there is no way to repair the cracked slide since it is molded plastic.
Posted on Jun 14, 2010
SOURCE: The large glass panel over the screen slides down.
I now have the same issue. What did you do?
Posted on Sep 04, 2010
Door panel fasteners need to be replaced on 1999 Plymouth breeze
Where is it loose?
If you mean the plastic fasteners, like bullet clips, or rubber things that go around the bottom and up the sides, they fit into slots in the heavy cardboard backing of the panel. You slide the old one over a bit and free it and slide the new one in. If the bottom is floppy, loose, or the sides, you just need 2 or 3 inches clearance to put new fasteners in. If you can get a good look at one, you will see which way they slide or are pushed over to remove them. There's about 6 or 8 along the bottom, but 3 well placed ones would hold it tight. If you can't get to them, though, or if you mean another fastener (I think there's only rather small screws and those plastic pins.) then you will have to take the panel off. First remove all screws, some may be hidden behind a speaker screen or a little square trim piece. Then slip a blade or thin screwdriver under the panel to pry out the plastic pins. Start at the bottom and work up the sides. When all are popped out, the panel should be loose. Lift out and up to clear the panel out of the window channel`. Pull all the electrical connectors you need to to get the panel free.
Well, good luck. Hope I've helped you some.
Jul 21, 2012 | 1999 Plymouth Breeze
Can I have a dog door in a sliding glass door?
It is possible to have a dog door in a sliding glassdoor. You open the door about a footwide and insert a panel that has a small dog door at the bottom. You are able to lock the panel to the windowand wall as well as lock the dog door itself. These are very common and useful products because most people don't wantto drill a hole through their front door!
May 15, 2012 | Pets - Others
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
A cracked plastic slide on my daughter's swing set
Nov 04, 2009 | Little Tikes Cubhouse Swingset
Need installation instructions for sliding shower door...probably #5475. When reinstalling, the inside door is swinging with nothing to secure the bottom.
not sure what you mean when inside door "swings" on a "sliding" door,...i'll assume you need the "inside door guide", a little plastic piece that screws with one screw to the main threshold,.....
Nov 02, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
The handle on the freezer door has broken loose and there is no apparent means to fasten it.
taking a guess on the model, but problem sounds similar to service calls in the past.
you should see two dogs bolted to the door, ok get your self centered look at the handle it should be clear where the handle slides behind the dogs.
pull the handle together at both ends,, to bow the handle, you can now slip both sides behind the dogs,,,,,
it should slide and lock in
Oct 03, 2009 | Amana Refrigerators
Feb 17, 2009 | Storkcraft Baby Aspen Stages Crib
The cover of detergent dispenser does not open..
It is most likely the flip spring...you need to be certain that the legs of the spring are inside the door edge and the spring does not swing freely...and there must be tension on the spring so that when the latch releases the door flips...you can also try this with an elastic, put the elastic inside the closed door and up around the drying solution knob, this will let the door flip open showing that the latch does work
Nov 11, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Pets - Others Logo
37 people viewed this question
Top Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Pets - Other Expert? Answer questions, earn points and help others
