Question about Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive
My toshiba 500 gb portable HDD is not being detected in any laptop.
SOURCE: 80 gb toshiba laptop is not detected in the bios.
When you power up the computer press F1 or F2 or "del" key then go to advanced .
Then disable SATA .
If already disable then enable it then save settings then check.
Let me know if you need more assistanse.
Thanks.
Posted on Aug 31, 2009
  • 69 Answers
SOURCE: Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Posted on Mar 11, 2010
Testimonial: "It worked... I never thought it could be that easy... Thanks a lot!!!"
henrylubanga
  • 128 Answers
SOURCE: I have a Toshiba (MK4004GAH)
You have to make sure that you have connected the HDD in the right way. Please open it and ensure that you placed the disk rightly into the casing with each pin tapping the rightful hole, see the casing's small manual. Note also that the laptop has to detect the casing as well, so cross check the casing to ensure that its working.
Posted on Dec 03, 2010
  • 39 Answers
SOURCE: I purchased a Toshiba Canvio
1 . Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
2. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
3.
Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
4. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs.
  • 5. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • 6. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Posted on Aug 30, 2011
    falachen121
    • 55 Answers
    SOURCE: I have unplugged my Toshiba
    try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover lost files.
    http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
    Posted on Dec 14, 2012
    How to turn on camera?
    Visit this link for toshiba laptop web cam support.
    Read More Help....
    How to activate the built in webcam on my Toshiba laptop
    and Toshiba Support
    Thanks,
    Jul 30, 2014 | Toshiba Satellite C50D-AST2NX1 Black 15.6"...
    Network controller driver for x875-Q7380
    Go to the computer manufacturer's site put in the system info and it will give all the drivers for your system search for the net work drivers and install it
    Feb 14, 2013 | Toshiba Qosmio X875-Q7380 - 17.3" - Core...
    I have unplugged my Toshiba Canvio 500 GB Basics Portable Hard Drive usb cable while transfering data, and my windows won't detect anymore. And i scan with some tools it says its have a bad sector at...
    Sep 05, 2011 | Toshiba Canvio Basics Portable 320 GB USB...
    I need to open my Toshiba Canvio portable disk.
    try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
    http://www.asoftech.com/adr/
    Aug 16, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
    Buffalo HDD 500 Gb portable, plugged it into my HP laptop and the blue LED on the Portable HDD just blinks even after the status bar oads, Normal or Problem?
    Its not a problem,whenever you will connect buffalo HDD to you laptop it will blink.
    Thanks for using FixYa.
    May 26, 2011 | Computers & Internet
    I have a Toshiba (MK4004GAH) 40 GB Hard Drive which was taken out from a Old Toshiba Laptop. I bought a 1.8" IDE casing with USB and connected to my new laptop....however, it fails to detect the HDD....
    Dec 03, 2010 | Toshiba (MK4004GAH) 40 GB Hard Drive
    Mar 11, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
    I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
    My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
    What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
    Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
    Jun 27, 2009 | Western Digital 320GB MyBook External USB...
    Hard drive detection
    You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
    Have a look at external HDD troubleshooting.
    Jules
    Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
    Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive Logo
    62 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
