Question about Bosch Nexxt 300 Series WFMC2201UC
Leaking water the grey plastic peice around the door bubble leaks. I just need that part I guess
    Problem Solver:
  • 14 Answers
If it is still under warranty, I would call customer service. If not, I would call the place you bought it, and explain the issue. I am sure they can order the part or give you somewhere to order it. Is it a removable seal? If so, you should be able to six it pretty easily yourself. here is the manual. Hope this helps.
http://www.ajmadison.com/ajmadison/itemdocs/9000224447_ver03_WFMC2201UC.pdf
Posted on Jul 31, 2013
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Water loss from radiator and bubbles when running.
Check your fill/refill bottle for cracks as most are made out of plastic and heat can crack them over time. hoses are a common source of leaks. if you are seeing bubbles then there is air circulating through the system some where, its common to open it and see the water flow but bubbles indicate a leak. the only other thing i can think of is to check your freeze plugs, you might have one damaged just enough to cause a small leak.
Jan 29, 2013 | Cars & Trucks
Water leaks from front of machine
dealng with a leak of this nature, it could be anything from a tear in the door boot (rubber peice between door and tub), a pin hole in the water pump or hoses, or a bad tub seal. Ideally you need to take the top off of the machine and run it to determine where exactly the water is coming from. One other thing to check, if you are using a detergent that suds up too much, a front load washing machine will leak around the door seal... they are designed for non-sudsing detergent.
Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
May 20, 2010 | Intex Easy Set Pool 15x36
Overheating and bubbling out of my overflow.How
Might be the heater matrix for the car heating system that is leaking in which case your carpets will be wet underneath
If the matrix is ok then I would hazard a guess that the block has cracked and gases are being forced into the cooling jacket around the block.
Fill the radiator leave the cap off, run the car stationary , watch the water , if there are lots of bubbles coming up from the radiator your head , block or gasket needs attention
Oct 15, 2009 | 1994 Acura Legend
1999 Blazer air/ water leak top forward corner
i've had leaks like this and they are hard to find,my solution is close all doors and windows turn on your heater blower to high and take a tablespoon of liquid dish soap and mix with water and then use a paint brush to apply and go around the windows and doors with this solution if you see bubbles you have found your leak, then you can fix the problem,hope this helps.
Sep 16, 2009 | 1997 Chevrolet Blazer
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
Water leak on fwd and back passenger side after every rain storm
pull your carpet up near the leak area and look for muddy body seams. it is possible one of the factory body seams are leaking- possibly in the cowl(under wipers) area, especially if it leaks when the car is sitting. there will be dirt/mud around the seams that are leaking. also you can check door seals by running the car on HIGH DEFROST with all doors and windows closed. spray around with a 50/50 soapy water solution. obviously bubbles will form around your leak.
May 28, 2009 | 2000 Toyota Camry
Water leaking from white plastic peice under washer
If this piece had 2 hoses attached and slides onto the motor, then it is the pump. you will need to replace it. Part # 3363394 available both new (27.99) and used (9.99) from timerking.com Hope this helps!
Jan 07, 2009 | Roper RAS6233KQ Top Load Washer
Water leaking from underneath after washer drains
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Bosch Nexxt 300 Series WFMC2201UC Logo
27 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
