Question about Refrigerators
I have an ice maker in a Kitchenaid KFIS25XVMS9 French door refrigerator that needs to be replaced. I need to know how to remove it.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 4 Answers
SOURCE: Maytag French Door Refrigerator with ice and water on the door
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Posted on Jul 06, 2007
peyton32034
  • 410 Answers
SOURCE: Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Posted on Jan 07, 2008
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
heatman101
  • 43501 Answers
SOURCE: LG french door refrigerator ice maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 11, 2010
Model KFIS25XVMS9. Why doesn't it make ice?
sounds like the ice maker is the problem not the inlet .
Oct 15, 2015 | KitchenAid Refrigerators
No water to icemaker Kitchenaid french door KFIS25XVMS9
There is several reasons that could cause this. First if your ice maker has a switch turn it off for about 15 seconds then turn it back on then the push the ice control paddle in 3 times. This should start the "harvest", reach up under the ice maker it should start to fell warm to hot which is good. Soon the kick out fingers will start to rotate. If it all is working well it will kick out the ice, then fill with water. If this all works but no water, then it could be a bad water fill solenoid valve, kink in the water line, water filter, frozen supply line. Let me tell you this is at times will have you scratching your head, so have fun.
Jul 23, 2014 | KitchenAid Refrigerators
I have a kitchenaid french door KFIS25XVMS9. The ice maker has stopped working.
If ice build up in the supply pipe sounds as water fill valve is dripping
May 22, 2014 | Refrigerators
Kitchenaid french door refrigerator not making ice
Water valve has 2 solenoids. One for water in door and one for water to ice maker. Most likely water valve is the problem b
Sep 16, 2017 | KitchenAid / Architect Series II...
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Ice maker not producting ice
Check that water is turned on.
Check temps in freezer below 15 degrees F.
Check that arm on Ice maker is not locked up in the off position.
Test water inlet vale by applying power if valve poers up and dispenses water ok replace the icemaker assembly.
Nov 02, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Ice maker not working
heatman101
uikg
May 19, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
Refrigerators Logo
424 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
