Question about Kyocera TASKalfa 180 Copier
Call servics.c6400 - Kyocera TASKalfa 180 Copier
  • Kyocera Expert
  • 337 Answers
Could be fuser unit but is often the dc power wupply board
Posted on Jan 01, 2014
How to reset a call c6400?
something to do with the printer not recognizing the power is on
and plugged in to the printer
could try
unplug the ac from the wall ..start again
if no better problem is internal ..call for service technician
Jun 15, 2016 | Kyocera Mita KM-1650 All-In-One Printer
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Kyocera Office Equipment & Supplies
C6400 on dispiay km 1650
Have to reset fuser in service mode.
Aug 28, 2014 | Kyocera Mita Office Equipment & Supplies
Call to service - C6400
C6400 indicates that you have a faulty fuser unit.
Oct 07, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
Display the Call service C6400 code
C6400 is a fixing unit error. You may need a new fixing unit but most of the time it can be reset in maintenance mode.
Use the following steps to enter the maintence mode, once there follow the steps for maintence mode 163 (reset fuser error). Do not do anything else in the maintenance mode area because you could damage your machine
Press the system menu/counter key.
Select Service setting using the up/down cursor keys.
While pressing the start key and the # key, press the enter key.
Select Maintenance mode using the up/down cursor keys.
Press the enter key.
Enter the maintenance item number (163) using the up/down keys.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Turning power switch off and back on
Resetting the fusing problem data
Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
Completion
Turning power switch off and back on.
I hope this is helpful,
Shawn
Dec 22, 2010 | Kyocera Copystar CS-1820 Black and White...
Call service c6400
it is the problem fuser unite heater lamp or thermostater
Jul 14, 2009 | Kyocera FS-1118MFP Laser Printer
Error c6400
A Copystar or Kyocera service technician must reset the fuser memory.
Jun 29, 2009 | Office Equipment & Supplies
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
Kyocera TASKalfa 180 Copier Logo
69 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
