Maintenance kit reset lexmark t650 - Office Equipment & Supplies
  • 2072 Answers
SOURCE: Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Posted on Jan 15, 2008
  • 58 Answers
SOURCE: New maintenance kit
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Cheers
Posted on Jun 27, 2008
  • 13 Answers
SOURCE: Reset maintenance counter
To reset the Maintenance counter yiu need to go into Config Mode.
Power on the printer while holding the 2 & the 6 button.
You will see the maintenence counter and can reset it from there.
Posted on May 28, 2009
  • 32 Answers
SOURCE: Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
Posted on Jul 24, 2009
wrinaldo
  • 185 Answers
SOURCE: RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Posted on Jul 31, 2009
How to reset Lexmark t650 fuser unit?
Fuser's don't have a 'reset'.....they just get hot and melt the Toner onto the paper.
I think you mean "how to reset the maintenamce counter".
Go to this page and watch this video for replacing the Fuser Kit on your model printer.
Lexmark T650 T652 T654 Fuser Maintenance Kit Replacement and How to...
Oct 13, 2014 | Computers & Internet
Lexmark 463de maintenance reset
To reset the maintenance page counter to zero:
1. Touch Reset Maintenance Counter from the Configuration Menu.
2. Reset Maintenance Counter appears in the header.
3. Touch 100K Kit or 600K Kit. Yes and No appear in a menu.
4. To cancel the reset operation, touch Back or No. All other button presses are ignored.
5. To initiate the reset operation, touch Yes.
Dec 03, 2012 | Lexmark "x463de multifunction laser...
Error 80 on a lexmark t642
Hello. Welcome to Fixya
Actually Error 80 is "Scheduled Maintenance Message"
You can reset the maintenance count by going to the Configuration Menu
Follow the given steps to solve it:
  • First of all Turn off your printer
  • Hold the 2 and 6 buttons while the printer is off
  • Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 seconds
  • On your Operator Panel, you should see "Configuration Menu"
  • Scroll down and look for "Reset Main Count" and select it.
  • Exit Configuration Menu and turn the printer off then back on
I hope it will be solved, If it doesn't work then
You are required to purchase the maintenance kit and have it replaced even if the printer is still under warranty. Some maintenance kits can be installed without the assistance of a technician. However, some warranties cover on-site installation of the maintenance kit by a technician after you have purchased the kit.
In this case you must be contact to LEXMARK service provider, To get support by LEXMARK on phone, then call at 1-800-539-6275
I hope this solution will surely helpful for u
If its is helpful then please don't forget to click on Four thumbs which are given below this solution
THANKS & Keep Using Fixya
Feb 28, 2011 | Lexmark T642 Laser Printer
How reset the printer maintenance counter for the lexmark t642
Here's an article in the Lexmark website on 80 Scheduled Maintenance" Message Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Included in this article are instructions on Resetting the maintenance counter to zero. Just click on this link: http://bit.ly/9pzU7R. Read thoroughly and follow the instructions carefully. Scroll down for the instructions on resetting the maintenance counter.
NOTE: RESETTING THE MAINTENANCE COUNTER SHOULD ONLY BE DONE ONLY AFTER REPLACING A NEW MAINTENANCE KIT.
Jun 29, 2010 | Lexmark T642 Laser Printer
After replace of a 100k kit, how can i make the reset of this?
Turn off the printer.Press and hold the Select and Right Arrow buttons simultaneously.Turn on the printer.Release the buttons after 10 seconds.Select Reset Maintenance Counter from the Configuration Menu.Reset Maintenance Counter appears in the header.Select 100K Kit or 600K Kit. Yes and No appear in a menu.To cancel the reset operation, select Back or No. All other button presses are ignored.To initiate the reset operation, select Yes. Gerrit Jan
Nov 10, 2009 | Lexmark C935dn Laser Printer
80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
Jun 11, 2009 | Lexmark T522 Laser Printer
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
jasbo
jasbo
