Question about SATO CL408e Label Printer
HOW TO RESET SATO GL408E - SATO CL408e Label Printer
IT WONT PRINT ANYTHING ALL OF A SUDDEN?
Your manual for the label printer should show you how to print a test label using controls on the front panel. Will it print such a label for you? If so, you more likely have a communication problem between your label printer and your computer(s). You should also be able to push a button to get a blank label to advance and come out of the machine. If you can't get a test label or get it to advance a label the problem is more likely with the printer itself. Make sure your paper sensor inside the machine is not clogged with paper fuzz, etc. Beyond checking your paper and ribbon paths, if you find nothing, you may need to call for a tech to see what is broken. Turning the printer off and back on again sometimes helps.
Jul 02, 2015 | SATO GL408e Label Printer
Ht 200 hi, i am trying to use my sato in free
Pano mag-install ng canon printer?
Pinagawa na ang printer namen pero hindi maka pag-print.
Aug 13, 2013 | SATO Office Equipment & Supplies
Hi, Sato CL408e, it starts printing between the labels. The feed is off by about 0.5cm. Any idea on how I can adgust that?
1) Try to calibrate the printer.
Else
do factory reset ( Press LINE and FEED At same time and switch on the printer.
Else
Change the potentiometer offset (Pitch,print) settings in the front panel.
Rgds
Mohan
Jan 21, 2011 | SATO CL408e Thermal Printer
Where can I obtain an RS232 cable for my MB 200 Sato printer
You can get one from most PC Dealers or Computer stores or buy one from eBay. Just select the required length of the cable, selct male / female connectors and number of pins as required for each end of the cable.
Oct 16, 2009 | SATO MB 200 Thermal Label Printer
All of a sudden it's printing in the middle of the label.
maybe its the problem with settings. try resetting it. good luck!
Oct 14, 2009 | SATO GL408e Label Printer
Spare Parts Catalog for SATO CL 408...
it is available on the Sato web site, by printer model
Oct 29, 2008 | SATO CL408e Thermal Printer
Pare parts in India for SATO CL408e printer
can better you to visit SATO website and get the information you wanted
Dec 27, 2007 | SATO CL408e Thermal Printer
SATO CL408e Label Printer Logo
127 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
mukhtar21 shaikh
mukhtar21 shaikh
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
