Question about Mitsubishi HC1600 Projector
Power light steady red and status light steady red
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Posted on Sep 11, 2008
  • 199 Answers
SOURCE: what does it mean when you have a flashing red
That it has engaged in a self diagnostic procedure as always on start up and has encountered an error. It is not allowing the system to "fire" up in order to prevent damage. Try unplugging the TV, waiting a few minutes, plugging it in and powering it up.
Posted on Sep 12, 2009
  • 84 Answers
Mitsubishi V26 error code 41 with solid red status indicator is caused by leakage from capacitors C9A37 and C9A38 (3300mf/16v). The result is a bad fuse F9A02 (15amp pico) which reports error code 41 indicating short protect. The Mits part number is 283P144040 but any PICO 15a fuse will work.
Bill W.
Integrityhomeworx.com
Posted on Mar 14, 2011
  • 336 Answers
SOURCE: misubishi wd-52631 DLP TV, it shuts off suddeny.
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Posted on Apr 19, 2011
Ecollier2012
  • 3459 Answers
SOURCE: Status light steady red
This is a common problem with many of the Mits sets...bad capacitors. google for part number Z1234TV to see if you can get the parts.
Posted on Apr 02, 2012
Mar 31, 2012 | Mitsubishi Televison & Video
The power light is solid red with no light on the status. I took out the bulb and put it back in now I have a solid red on the power and a solid yellow on the status. There is also no sounds coming from...
steady red with yellow/orange status light indicates that the temperature is too high, so by the sounds of it your device has malfunctioned, you need to get a repair on this
see page 44 here
http://vis.mitsubishielectric.co.uk/files/library/files/hc3800_manual.pdf
different model but same error code
Mar 06, 2011 | Mitsubishi HC3000U Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
Powers on for only a few seconds
if the power light blinks and the status light is off, check the lamp door. if the power light blinks and the status light is steady red or blinking green, you have a power supply/ballast issue. you may have to send it in for repair. try www.avsolutionsny.com.
Dec 09, 2009 | Mitsubishi XL8U Multimedia Projector
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Nec projector vt440 wont turn on
Hello. First check the lamp! From your description, it sounds like the projector is telling you that the lamp needs to be replaced. In "eco mode", when the power is green and the status is steady orange, that is the error message. In "high brightness mode" the status will be steady red. Hope I helped you.
Feb 22, 2009 | NEC MultiSync VT440 Multimedia Projector
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi HC1600 Projector Logo
27 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
