Question about Jensen Vm9224 Car Video Player
My screan looks like a (color bar code) half of the screan has the bar codes line the other is blank the screan does light up when i turn on the radio
We have a Raypak Water Heater Boiler Model # H9-2002. Our problem is the boiler don't give to much heat The Safety Ignition light is red and I check the Fenwal Diagnostic Status Codes it is blinking 3...
is it a combi boiler pressure system if it is they need about 6 bar of water you have to top them up once in a while there are taps on them you turn one off and the other on dont turn the gas one off look at the instuctions you will hear the water coming in and turn it off when it gets to 6 bar about half way up on your gauge do not fill up passed the red line its about half way between 0 and the red
Nov 06, 2011 | Pool & Spa
When tv is turned on, only half of pic is there (left side)..The right side looks like a bar code, with horz. and vertical lines..There is color behind these lines....After it warms up or a couple hours...
This tv is a standard CRT(tube tv) wright?Yes,than the tv video board have problem with dying capacitors or the main colors decoders IC require resoldering.U have a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders and also understanding basic electronic wright?Take the tv aparts check all those capactors all around the main colors decoders IC for capacitors leakages,replaced all these dying leakages capacitors,will solved this problems.These capacitors alway bulges up or puffing up on it top.That the indication those capacitors are dying and not working to it full capacity.Also resolders the colors decoders IC too.Ur tv problems,will be solved.
Nov 15, 2010 | Sylvania Televison & Video
The touch screan is frozen
Sounds like a bad touchscreen. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jun 12, 2010 | Garmin Nuvi 660 GPS Receiver
Blank screan
Greetings,
Please go through the Website link mentioned below.
http://www.nintendo.com/consumer/systems/ds/index.jsp
Please let me know if you have any issues.
Regards,
Feb 09, 2010 | Nintendo DSi Black Console
The code has been lock and the screan pls help to open because the picture is blank
Thanks. How do you unlock the code? (BTW, I'm new to FixYa and saw your posting right after I posted my problem. So am not sure if you're answering mine or not.)
Jan 01, 2009 | Televison & Video
42"panasonic plazama
send it back to wea you purchased it and get them to replace it or refund your money
Sep 23, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
IBM Flat Panel Monitor problem - light colored shifting lines (like Bar Codes)
It sounds like it's a problem with the video card, as opposed to a problem with the monitor. If you have another machine, or a laptop, or a friend with a laptop you can find out - just plug it into the other machine, and if the problem goes away, it's the video card. If not, it's the monitor.
While the card may be bad (if it has a dead fan, and has overheated) you will probably need to replace it. But if may just be loose, assuming it is a and on video card and not an onboard one. If it is an onboard video, you can usually disable it and put in an add on video card, which would resolve the issue as well.
Feb 16, 2008 | Computers & Internet
Moved the tv and now have a line on bar in top half with bend to it?
sounds like solder on convergence amps has hairline crack's
needs resoldering...
Oct 19, 2007 | Toshiba 51H84 51" Rear Projection...
Jensen Vm9224 Car Video Player Logo
101 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
