Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
36" Sony Trinitron Wega Model#KV - 36HS510
I've had my Tv for about 4 years. About 6 months ago I started to have problems powering it up. I've had it fixed by repairmen twice and it still won't power up. These are the parts replaced so far 1. Flyback Transformer 2. HO Transistor 3. 2 Double FET's 4. Reg. Driver IC 5. 6 Filters 2nd time repaired 1. PS Driver IC 2. 4 Filters
Problem is cool joint all solder is no good cause tv to not turn on
Posted on Apr 17, 2008
Get a Qualified repairman!
Posted on Dec 06, 2007
SOURCE:
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV wont turn on. Standby light blinking 7 times in sequence.
It will most likely need the power on switch replaced its very common
Jun 21, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Trinitron 36" TV
How many flashes is it flashing. usually when you have audio but no video its a vertical deflection problem. Try resoldering the vertical output IC to see if that helps.
Mar 27, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony WEGA KV-36FV15: Picture problems
I THINK YOU HAVE A PROBLEM WITH DEFLECTION - I SUGGEST TO REPAIR IT BY TECHNICIANS - THAT TV IS UNDER
WARRANTY - DELFO
Mar 20, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
148 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
