Question about Whirlpool GS470LEM Gas Kitchen Range
Indesit wg635tp manual What should the ARROW
Indesit wg635tp manual What should the ARROW setting be that's connected to the Timer?? I notice a "pointing arrow" through an opening, and need to know the setting when the machine is in the OFF position...
3 Suggested Answers
  • 289 Answers
SOURCE: Just moved into a home with a Duet washing machine
first you nead to make sure that the unit is level,the part # for the laundry guide is part#8182239
Posted on Jan 03, 2010
Jahn27
  • 1554 Answers
SOURCE: the start/ stop knob of my whirlpool washer
The threads either on the timer knob (part number 3364291) and the timer dial ( Part number 3957849, the larger part of the timer with arrow) are worn. Pull the knob off and inspect the threads. Replace the part with the worn threads.
Posted on Jun 08, 2010
Cannot use the up and down arrow buttons to change wash cycles
X-Stream Wash Installation and Operation Manual (PDF)
dukemfg.com/wp-content/.../3/.../115152-Manual-X-Stream-Wash.pdf
Installation and Operation of X-STREAM WASH. 2 ..... Duke Manufacturing Co. cannotassume liability for .... be placed in the wash tank during a wash cycle. .... Down Arrow Button Pressing this button, while not in the temperature set point mode, will display the time ... Use the Up or Down buttons to change the temperature.
[PDF]HYDRIM L110w - SciCan
www.scicanusa.com/site/scicanusa/assets/pdf/scican_hydrim_l110w.pdf
Thank you for selecting the Hydrim L110w instrument washer. The Hydrim ... Contents of this manual are subject to change without notice to reflect changes and ... Down Arrow - used to adjust a value down, or to move between screens in a menu .....button is pressed, the cycle is aborted and cannot be re-started.
[PDF]using the timetech timer tts-4/tts-8 (mfg ... - AJ Antunes & Co.
ajantunes.com/portals/0/productdocs/1010878.pdf
The TimeTech Timer uses four or eight timing channels to track four or eight different ...Use the Up and Down arrow buttons to select the desired Time Stage and .
Jan 20, 2016 | Washing Machines
How to set a tork timer
1) Copy following link to identify timer, and download possible manual:
http://waterheatertimer.org/Tork-timers-and-manuals.html
2) Tork TU universal
http://waterheatertimer.org/How-to-set-timers.html
3) Usually the dial will rotate manually until current time lines up with Time arrow located next to override lever, or time arrow located on inner dial, depending on model number.
4) Tork DTU digital timer:
http://waterheatertimer.org/How-to-wire-Tork-DTU40-timer.html
5) After opening links to identify timer, add comment and describe where you are, and what you discover.
Feb 20, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
How do you override the timer if you want to turn off or on outside the preset timer programme
1) Is this the Towerchron QE2?
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB instructions.pdf
2) Page 8: While slide switch is in run-own-program or run-preset-program mode, you can override by pressing select button until arrow points to Boost, or arrow points to ADV.
This will reverse program until next set point.
3) Add comment and describe which timer you have.
Jan 29, 2013 | Water Heaters
Find the time now arrow to reset
1) Question posted under Woods 59017 analog timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
2) On the Woods 59017, the 'arrow' or triangle is a hollow triangle shape on inner timer dial. It points at the 3:00 position.
Manually rotate dial until current time lines up with arrow, arrowhead, or triangle.
3) On other analog timers, the time-now 'arrow' is usually small dark-colored triangle or arrowhead located on stationary part of inner dial.
4) Open following link to see how to set and use analog timers by experimenting with each feature.
Plus images of time-now arrowhead or triangle.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Woods 59017 Mechanical Repeats Daily Wall...
The clock dial on my grasslin analog timer does not correspond to the time on the "2:00" arrow. how do i realign the clock dial to be in line with the arrow?
I don't know what the 2:00 o'clock arrow is.
KM series Arrowhead is located to right side of timer dial.
To set clock, manually rotate timer dial clockwise until current time lines up with arrowhead
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#KM
If this is not your timer, then add a comment with description of timer for possible help
Jul 23, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
HOW DO I SET THE WOODS INDOOR TIMER? I WANT TO USE IT TO TURN A LAMP ON AT 7:00P.M. AND OFF AT 6:00A.M. ALSO, DOES IT STAY IN THE TIMER ON POSITION ALL THE TIME? THANK YOU.
with a timer like that , start here. Unplg it and have it in your hand. Pull up all the tabs. Push down the tabs from 7pm-6am. Now, find in the center ot the unit, the little arrow, turn till the correct time, the the right now is at the arrow. Plug in right away. As for the timer switch, timer on will work just as timer, push to outlet on will turn the lamp on manually. Also keep in mind that if the power goes you will have to realign the arrow with the actual time.
Mar 06, 2011 | Woods 59200 Lamp and Appliance Timer with...
I have the ET420C that I want to run about 2 hours per day to chlorinate my spa. I cannot figure out anything from reading that manual. How do I set it up to run every day for about 2 hours?
ET420C manual is longer than space allowed for free answer.
Moreover, this manual leaves off key steps and is totally unclear, just as you discovered.
http://waterheatertimer.org/pdf/ET420C-Manual.pdf
On-line manual has page numbers, but pages are not in order, so look carefully at page numbers.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET420C
1) Let me work alongside you while we look go through manual.
2) This timer is simple electronic clock, like alarm clock.
Look at page 3 of manual about setting the clock. (Remember to look carefully at page numbers)
Clock needs to know what time it is at your house right now.
Manual shows 10 steps for setting current time.
You use arrow keys to set clock.
3) Next look at page 4 "program settings"
Use arrow keys to select program number
Program number 1 thru 20 appear on display
In my opinion, it appears that program1 is ON, and program2 is OFF
So program1 will be when you want chlorinator to turn ON
Program2 will be when you want clorinator to turn OFF
The manual is missing this key detail, so look at display to see if it shows program1 ON and program1 OFF ... if the ON and OFF do not display, then timer sets as described above.
Make sure you set same days for ON and OFF times >> if programs have conflicts, then timer will not operate as expected.
How to set programs:
Use arrow keys to select program1 and then press SET
Use arrow keys to select day, and then SET, and then arrow keys to select hour, and then SET, and then arrow keys to select minutes, and then SET.
Repeat steps for program2.
4) Mode appears on page 7 of manual
Again the manual is totally unclear how to set MODE or what buttons are pushed
I have the opinion that you do not set MODE unless you use Countdown or Random feature.
So see if timer operates without setting MODE
5) Add a comment if you get stuck, and I will review manual with you while you push the buttons.
You can add as many comments as needed, and I will respond as needed.
6) For heavy-duty outdoor timer with fewer functions, that is easier to program:
Up to 1/4 Hp, 1000Watts
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
Or
http://www.amazon.com/Intermatic-HB800RCL-Seven-Outdoor-Digital/dp/B001KBZUNK
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 20, 2011 | UPM Programmable Outdoor Timer
I need to program the timer
http://waterheatertimer.org/Paragon-EC4000-program.pdf
4 Buttons RUN MODE Arrow ENTER
Programming steps are long but straightforward
16 set points
Selectable clock format - 12 hour/ 24 hour
Day skipper
Manual has troubleshoot section, so expect the usual trouble
Wiring diagram at bottom shows 5 poles for 120V timer.
Hot and Neutral connect to poles 1 and 2
Jumper from Hot to pole 3
NC normally closed pole 5
NO normally open pole 4
Black from load connects to pole 4 or 5
White from load connects to Neutral at pole 1 or 2
Sep 28, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Timer Recording
This is from the KR10 manual. Hope it helps.
1. Set the clock before setting a timer.
2. Insert a recordable disc with enough space.
Then:
1. Press [TIMER PROG] on the remote
2. Use up/down arrows to select "New Program" then press [ENTER]
3.Use up/down arrows to enter the date, then press right arrow
4. Use the arrow keys to enter the start and end time, then press right arrow key.
5. Use the up/down arrows to select the external input position to which your cable/satellite box is connected, then press [right arrow]
6. Use the up/down arrows to select a recording mode.
7. Press [ENTER] when all items are entered.
8. Press red [I/O ON STANDBY] to set a timer programming.
DO NOT FORGET THIS LAST STEP! The timers will not work if the recorder is not in standby mode.
Jul 24, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Delay timer
You can download the manuals for the PowerShot SD600 here.
To use the self timer feature, you need to set it up in the menu first.
1. Press the Menu button. If not in the shooting menu (silhouette of a camera), use the left or right arrow to get there.
2. Use the down arrow to select Self Timer.
3. Use the right arrow to select the clockface with a 2 or a 10 (2 second or 10 second delay).
4. Press the Func./Set button.
5. Press the Menu button to exit.
Once set up, you can activate it by pressing on the down arrow. You should see an icon change from a rectangle to a clockface at the top center of the LCD when the self timer mode is selected. Press the down button again to cancel the self timer mode.
Apr 24, 2008 | Canon PowerShot SD600 Digital Camera
Whirlpool GS470LEM Gas Kitchen Range Logo
109 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
