Question about Vision Panini My X 60 Check Scanner
In Add/Remove programs, I choose to "Remove" the Vision X drivers and it states at the end that it has been uninstalled but it has not. Vision X still is in the list of Programs. When I try to install new Vision X drivers it tells me that it needs to uninstall the old ones first, it then states that the uninstall is complete, but it will not continue with the install of the new drivers, it simply states "Please Wait" but does not proceed. The old drivers still exist in Add/Remove programs and each time I try to uninstall the drivers it states that it was uninstalled but it has not.
How do i get rid of http://gon.driveopen.net/ pop up
Step 1, Follow such steps to open task manager and end the malicious processes related with interyield.jmp9.
1) Please press Ctrl+Alt+Delete key together to get the task manager box,
2) Tick the malicious processes.
3) Tap the End process button.
Step 2, Go to control panel, and then search Related Readings program and related programs with interyield.jmp9 and then delete all of them.
Go to Control Panel -> Add and Remove programs list and uninstalling it from there.
Step 3, Remove add-ons on your infected browsers:
Internet Explorer:
1) Go to Tools -> 'Manage Add-ons';
2) Choose 'Search Providers' -> choose 'Bing' search engine or 'Google' search engine and make it default;
3) Select 'Search Results' and click 'Remove' to remove it;
If you still don't know how to do , please search TEESUPPORT for help.
Jan 29, 2014 | Audio Players & Recorders
How can i ununstall softice..Please people help me because my skype is not working
Well, depending on what version of windows you use, typically you would goto add/remove programs or programs and features located in the control panel, then find the entry for softice and choose uninstall. If this has been done and it is still giving you problems, you may need to take further steps involving the removal of any folders named softice, If it just needs a simple uninstall then go to Start, then control panel, then add/remove or programs and features (uninstall programs)
Oct 11, 2013 | Compuware SoftICE Driver Suite for PC
Computer is running slow may have a virus
Sounds like you have the We-Care.com app installed; it's a free online donation tool. You may have downloaded it along with a disk utility or some other freeware. If you're getting a popup message, you're probably having issues. Contact them at the email address, or uninstall by following directions below:
Open your Start menu and choose Control Panel.
In Windows XP: choose Add/Remove Programs.
In Vista: choose Programs/Features.
In Windows 7: Choose Uninstall a program.
Find the We-Care Reminder (may be ASPCA Reminder by We-Care.com).
Choose Remove (Windows XP), or right click and select uninstall (Vista and Win 7).
Dec 06, 2011 | E-Machines eMachines Desktop PC
Cant uninstall driver for a4tech cam pk-635 from uninstall programs for win 7.. getting error message >SetupDLL\SetupDLL.cpp(409)$7.0.100.132@Windows XP (7600) IE 8.0.7600.16800
You try uninstall driver of a4tech to add / remove programs you go to control panel you open add / remove programs then you wait till all the programs comes out then if you see the program or driver of a4tech in the programs list just clik then wait for the instruction remove this program or uninstall this program then if you like to uninstall just choose uninstall or remove which ever then wait for the uninstalling process.
Hope i can help for your a little problem.
Best regards,
Lito E. Fidel
Jun 28, 2011 | A4tech PK-635 Webcam
Have a Lexmark x84-x85 it will not print nor can I uninstall from computer to reinstall what can I do?
Hi
Go to start, choose control panel, choose add/remove programs, right click mouse and choose remove.
Another is try to run your computer on SAFE MODE and then uninstall the printer driver by pressing F8 key when start up boot and then choose run on safe mode. Once system is load, go to control panel and choose add/remove programs and then uninstall the printer driver.
Jun 21, 2011 | Lexmark Office Equipment & Supplies
Message states msn toolbar has error code 400. how do i fix this
I would suggest you to uninstall the toolbar and check. Follow the steps mentioned below.
a.Close all Internet browsers.
b.Uninstall the toolbar through your "Add/Remove Programs" utility. Choose the "Start" button in the lower left-hand corner of your computer screen, and then click "Control Panel." Choose "Add/Remove Programs" and the programs that are installed on your PC will be listed. Choose "MSN toolbar" and then "Change/Remove." You will be instructed to verify if you wish to continue with the uninstall. Choose "OK" and continue to follow the instructions by choosing "Next" until the uninstall completes.
c.Uninstall the toolbar by using the "Run" utility if you are running Windows XP. Click "Start" and then "Run" and type "appwiz.cpl" in the text box. Press "Enter" and the programs that are installed on your PC will be listed. Choose "MSN toolbar" and click "Remove." You will be instructed to verify if you wish to continue with uninstall. Choose "OK" and continue to follow the instructions until uninstall completes.
d.Open a browser and verify that the MSN toolbar is no longer displayed. You may need to restart your PC after uninstall is complete.
May 17, 2011 | Microsoft Internet Explorer 7
The driver was not installed. You did not accept the certificate required during installation. (DTD8008)
We have got the same issue too when using the desktop deposit function.
The tech support basically did 2 things to resolve the issue:
  • In Internet Explorer
Oct 05, 2010 | Vision Panini My X 60 Check Scanner
My itunes just stopped working one day and now i can not reinstall it on my computer
Learn how to completely uninstall iTunes, QuickTime, and other essential software components from your Windows XP PC.
How ToFor Windows Vista or Windows 7, see this article.
Expand All Sections | Collapse All Sections
In some rare instances, it may be necessary to remove all traces of iTunes, QuickTime, and related software components from your computer before reinstalling iTunes.
Use the Control Panel to uninstall iTunes and related software components in the following order:
  1. iTunes
  2. QuickTime
  3. Apple Software Update
  4. Apple Mobile Device Support
  5. Bonjour
  6. Apple Application Support (iTunes 9 or later)
Important: You may see various alert messages if you uninstall these applications in a different order or only uninstall certain components.
For detailed steps on removing and reinstalling iTunes and related components on Windows XP, refer to the following steps:
Removing iTunes Note: iTunes Store purchases or songs imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
  1. Quit iTunes.
  2. From the Start menu, choose Control Panel.
  3. In Control Panel, open Add or Remove Programs.
  4. Select iTunes from the list of currently installed programs, then click Remove.
  5. When asked if you would like to remove iTunes, select Yes.
  6. After the uninstallation is complete, do not restart your computer if you are prompted to.
  7. If other program entries were listed for iTunes in Add or Remove Programs, remove those as well.
  8. In Add or Remove Programs, remove any iPod Updater applications that are listed in the same fashion as iTunes was removed.
Removing QuickTime
  1. Quit QuickTime Player.
  4. Select QuickTime from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove QuickTime, click Yes.
  7. If other program entries were listed for QuickTime in Add or Remove Programs, remove those as well.
Removing Apple Software Update
  1. Quit Apple Software Update.
  4. Select Apple Software Update from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove Apple Software Update, click Yes.
  7. If other program entries were listed for Apple Software Update in Add or Remove Programs, remove those as well.
Removing Apple Mobile Device Support
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, open Add or Remove Programs.
  3. Select Apple Mobile Device Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Mobile Device Support, click Yes.
  5. After the uninstallation is complete, do not restart your computer if you are prompted to.
Notes: Do not manually delete the Mobile Device Support folder located at C:Program FilesCommon FilesApple. Use Add or Remove Programs as described in the steps above.
Removing Bonjour
  2. In Control Panel click "Add or Remove Programs."
  3. Select Bonjour from the list of currently installed programs then click Uninstall.
  4. When asked if you would like to remove Bonjour click Yes.
  5. After the uninstallation is complete do not restart your computer if you are prompted to.
Removing Apple Application Support (iTunes 9 or later)
  3. Select Apple Application Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Application Support, click Yes.
Verify iTunes and related components are completely uninstalled
  1. Restart your computer.
  2. After the computer restarts, open Local Disk (C:) located in Computer or whichever hard disk your programs are installed on.
  3. Open the Program Files folder.
  4. Right-click the iTunes folder, choose Delete, and choose Yes when asked to confirm the deletion. Note: This folder may have already been deleted if iTunes was successfully removed.
  5. Right-click the iPod folder, choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  6. Right-click the QuickTime folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  7. Right-click the Bonjour folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  8. Open the Common Files folder.
  9. Right-click the Apple folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  10. Open Local Disk (C:) located in Computer or whichever hard disk your operating system is installed on.
  11. Open the Windows folder.
  12. Open the System32 folder.
  13. Right-click the QuickTime file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  14. Right-click the QuickTimeVR file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  15. Right-click the Recycle Bin and choose Empty Recycle Bin
Reinstalling iTunes and related components After verifying that iTunes is completely uninstalled, you should download and install the latest version of iTunes.
Additional Information iPodService.exe Alert Follow these steps if the message, "Cannot delete iPodService.exe: It is being used by another person or program" appears when you try to delete the iPod folder.
  1. Make sure that iTunes and the iPod Updater utility are not open.
  2. Press and hold Control-Alt-Delete. Select Start Task Manager.
  3. Click the Processes tab.
  4. Locate "iPodService.exe" in the list.
  5. Click "iPodService.exe" and choose End Process.
  6. Quit the Task Manager.
Aug 04, 2010 | Apple iTunes
Constant restart in XPsp3. unable to complete startup in normal mode, only in safe mode.
If you havent already treied to remove it from the Add/Remove Programs I would check that first by clicking Start > Run > type
appwiz.cpl and press Enter. This will open Add/Remove programs and from there you can choose Windows XP Service Pack 3 the click remove. This should start the uninstall process. You may have to click finish to restart at the end.
If the machine starts in safe mode and you see the dialog that states that you are working in safe mode... instead of choosing yes choose no and it should start the system restore feature.
From there you will choose restore your computer to an earlier time and click Next. After that you will have a calendar with bold dates on it. These are the dates that have restore points available. Just select a date of when you know the computer was working correctly and then choose an entry on the right of th lastest time that you know it worked. It is usually a good idea to choose from ones that say "System checkpoint". After you select it click Next. It should bring up a screen verifying that it the point that you want to use. If so, click Next and your machine will restart and be brough back to the state that it was in accoring to the restore point you choose.
Here is a link from Microsoft that will also explain some other processes that you can use.
http://support.microsoft.com/kb/950249
Thanks
Jul 21, 2008 | Computers & Internet
Before installing Windows XP Upgrade
In order to update your system from the current Windows operating system to Windows XP Home, there are several steps that need to be taken prior to upgrading. Please follow the items listed below in order to prepare for Windows XP. Uninstall Trend PC-cillin2000 Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click install/Uninstall tab, select "Trend PC-cillin 2000". Click the Add/Remove button to uninstall "Trend PC-cillin 2000". Uninstall NTI CD-Maker 2000* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the Install/Uninstall tab, select "NTI CD-Maker 2000". Click the Add/Remove button to uninstall "NTI CD-Maker 2000". Uninstall Intel LANDesk Client Manager* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "Intel LANDesk Client Manager 6". Click the Add/Remove button to uninstall "Intel LANDesk Client Manager". Uninstall PowerDVD* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "PowerDVD". Click the Add/Remove button to uninstall "PowerDVD". * This software is optional. If this software is not installed previously, please skip the step.
Sep 11, 2005 | Acer n10 Pocket PC
Top Vision Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Vision Office Equipment and Supply Expert? Answer questions, earn points and help others
