Question about Dell Inspiron 570 Desktop PC (I5707163PBK)
Launch manager dritek - Dell Inspiron 570 Desktop PC (I5707163PBK)
check to see if was disabled at start up...also you can in services to if it was disabled as well....if all else fails....re install it
Nov 13, 2013 | Acer Aspire Computers & Internet
Bluetooth aspire 9420
Please do the following steps...
1. Download the bluetooth driver - 'Bluetooth_Broadcom_6.0.1.3500_VistaX86', its the one for vista but works for win7. After the drivers installed sucessfully the bluetooth still didn't work as the bluetooth hardware wasn't turned on, pressing the bluetooth button to the left of the keyboard didn't do anything for me.
The driver is available from the Acer website below under the Vista section, just click through the categories notebook/model/OS/drivers etc until you reach it.
http://global-download.acer.com/GDHome.aspx?SC=PA_6&LC=en
2. Next download Dritek Launch Manager - 'LaunMgr_Dritek_1.1.1.3_VistaX86' (this utility controls the assignment of shortcuts/applications to the other buttons on the keyboard) from the Acer website above, it'll be under the applications tab instead of drivers.
For some reason the Launch manager zip also includes another zip of the drivers for the Nvidia Video Card, I can't see why they're bundled together but it is Acer after all.
After the launch manager had installed the dedicated bluetooth button worked just fine first press, but bizzarely this application doesn't allow you to assign the bluetooth button, just the other 4 buttons above the keyboard.
But it clearly fixed my issue so it must have installed something which brought the bluetooth button back to life.
BTW the Launch Manager doesn't even have to be running for the bluetooth button to work.
Hope this fixes your issue.
Mar 16, 2013 | Acer Aspire 4720 Notebook
Laptop CHL model has a very dim light on its LCD. Tried to adjust from its keyboard contrast but not working
u need to spesify the product. normally u need to install the keyboard driver or dritek launch manager (for acer), or launch manager for hp. try to install those driver first and adjust from it's keyboard. hope this will help you.
Jun 13, 2012 | ViewSonic Computers & Internet
Will not reload windows 7
try to start windows on safe mode by pressing F8 prior to boot to windows, choose safe mode. Go to Programs and Features under Control Panel, and uninstal Dritek Launch Manager
Dec 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi my acer aspire 5315 e button at the top dose not work so do you now who to fix this
Hello reeceman1,
The Acer Launch Manager needs to be running for the 'e' key to work. To run the Acer Launch manager, do these 3 steps:
* Click the windows start button (bottom left-hand corner) * Click All Programs * Click 'Launch Manager'
When the Launch manager window displays on the screen, click OK. Now Press the 'e' button and it will launch the Acer Empowering Technology
If this solution is helpful please click a thumbs-up rating.
Have a great day, martyshaw152
Apr 09, 2011 | Acer Aspire 5315 Notebook
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
I have the Aspire 5630 and I'm using windows 7 but I want the setup file of the launch manager because the multimedia buttons don't work. Thnx.
Alright, so I have the Aspire 5630 and after installing Windows 7 32 bit, the media keys did not work. Just installing the latest Launch Manager didn't work. But here's what did work for me: Install the 3.0.04 version of the Launch Manager (LaunchManager_Dritek_3.0.04_W7x64W7x86_A.zip) If the link doesn't work, just select the Acer Aspire 7730 in the Service & Support section of their website, choose Windows 7 as the OS, and you'll see the Launch Manager under the Application tab.
After installing that and rebooting, the media still didn't work for me (though another user reports that they worked at this point). What I then did was download the latest Launch Manager for the Aspire 5630 for Vista (same deal as before if the link doesn't work, but select the 5630 and Vista instead). Extract the .zip, then take the "LManager.exe" file from the zip and replace the one in "C:program filesLaunch Manager" (back up the existing one if you so desire.) If Launch Manager is already running, right click on it's icon in tray and close it, then launch the one you just copied over (which will also now be the one that is launched automatically on start).
At this point, all of my media keys were working.
Hope this helps!
Dec 22, 2009 | Acer Aspire 5630 Notebook
Acer aspire 5630. The volume, play, stop won't work
re-install the original drivers and program for control buttons.
Jun 04, 2009 | Acer Aspire 5500 5570-2609 Laptop
My CineDash Media Console will not work anymore. The volume, stop, play, etc. does not work. Not with itunes anymore.
This is the way to get it to work!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager here (hosted here) or go to the acer site and find it there. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Nov 06, 2008 | Computers & Internet
My cineDash media console has stopped working
Confirm that this solution work very well. Thank you.
Jul 07, 2008 | Audio Players & Recorders
Dell Inspiron 570 Desktop PC (I5707163PBK) Logo
mukhtar21 shaikh
mukhtar21 shaikh
