Shredcare com Model #lm80b
Need a manual
Need to know what you need a manual for?
Apr 17, 2015 | Audio Players & Recorders
Shredcare com
They can but economically depends on the value of the unit and the make and also if the parts are avalible to buy. Normally the gears can be replaced by buying kits offline. The gears are normally attached using a Cir-clip round ring holder or a split pin, should be straight forward repair.
Aug 14, 2014 | Office Equipment & Supplies
Shredcare com
Many shredders will jam up with pieces of the shredded bits sticking inside. If it gets near the trigger mechanism that is pushed inside so that it can be pushed, it STOPS! Unplug it, use tweezers and gently but consistently try to pull out all the remnants. If you get it all out, and it can take a while, it should start up again. In the future oil the machine with the special oil they make for shredders sold where you bought the shredder... and only shred a few pieces at a time. Go backwards only to UNJAM. If it is jamming you have to fat a load of paper going through.....GOOD LUCK!
Jul 25, 2014 | Office Equipment & Supplies
Shredcare com
Look for damage around a paper feed limit switch, this may be the problem
Aug 23, 2013 | Office Equipment & Supplies
Shredcare model # TQ100B
shredcare is the worst company ever. they sell crappy merchandise and then when it breaks, they dont sell replacement parts. My machine was out of warranty and the motor spindle sheered the teeth from the 1st cog wheel. this is probably an $0.11 part, but shredcare says my only option is to just buy a whole new unit and send this one off to the land fill, even though its so easily repaired.
i will never do business with shredcare again, and recommend everyone else stay away from them as well.
Feb 18, 2009 | OfficeMax 0M96431 Shredder
OM 99727 shredder not working
I had this same problem. This is what I did to fix it.
When I went to ShredCare.com (the recommended web site for technical support of this particular shredder), I read that 'Most models of shredders have a safety interlock switch that is activated by the basket.' Upon looking closely at my basket and the shredder, I found this safetly interlock switch and made sure to align it with the proper position within the basket. There is only ONE way to place the shredder on the basket and have this safety interlock switch activated. The switch is located on the underside of the shredder. Align this switch with the ridge on the inside of the basket. Listen carefully and you will hear the switch 'click' when in the right position. Mine is very touchy. I've even had to press in on the side of the basket while shredding to make sure that the ridge and the switch are making contact.
Hope this helps!
Aug 15, 2008 | OfficeMax 0M96431 Shredder
jasbo
jasbo
