Good
Morning Chris, thank you for your inquiry! Here are a few troubleshooting tips
that may help you get to the root cause.
First, be sure that the washer leveling legs are evenly installed.
Verify that the unit is sitting solidly on the floor.
The load made be out of balance. Make sure the washer is loaded
properly for the setting chosen.
· Confirm all shipping material was removed during the installation process.
If the
washer continues to vibrate, I would suggest consulting a professional to
accurately diagnose and repair the appliance.
SOURCE: brand new electrolux front load washer w/ factory
Although you say it's level I would recommend you try my method to make absolutely certain!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
