Question about HP Photosmart 5520 e-All-in-One Printer
I have a HP photosmart 5520 copier. It is cutting off about one inch off the top and bottom of the document and is printing everything in red. The document has red green and black colors on the original.
  • 16 Answers
SOURCE: HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Posted on Jan 05, 2008
wayneard
  • 1901 Answers
SOURCE: Custom Paper Sizes for HP Photosmart C3180
I have a 3100 series HP. On it you select "Properties", then the "Features" tab. On that tab, there is a "Resizing Options" menu item. It has a drop down menu with "Letter", "More...", and "Custom" choices. There you can define the size.
Posted on Oct 15, 2008
dixibabe82
  • 54 Answers
SOURCE: HP c3180 color printing problems
I would definitely start by printing a self-test page. With your model press and hold the Cancel button and then press the Start Color Copy button and then release both buttons. When this page comes out you should be able to identify the 4 different color sections...black, cyan, magenta and yellow. If any of these seperate areas are choppy or non-existant, you need to replace your cartridge. Here is a link that will show you examples of what you should/shouldn't see on the self-test report.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00661556&lc=en&dlc=en&cc=us&product=1146331&rule=25470&lang=en
Posted on Mar 30, 2009
SOURCE: HP 7410 streaks when using auto document feeder to make copies
Lift the cover of the fax/scanner/copier. The glass area has 2 sections, a small section and a large section. Clean the small glass section with damp cloth. I had 3 black streaks caused by 3 black dots on that glass. I also cleaned the rollers on the ADF, but that was not the problem.
Posted on Jun 27, 2009
SOURCE: Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Posted on Aug 17, 2009
How do I get my HP Photosmart 5520 series to print from the front as opposed to the queue?
Evelyn, I think you're a little confused, the print queue is created when the printer is in standby mode, or you're sending documents to print faster than the printer can deal with them.
Printing from the front, I assume, is from the front tray where the paper is.
When you send something to print, you see a little printer icon appear near the clock (bottom right), double click it and a window opens, click printer and if use printer offline has a tick at te side of it, click on it and it will release the print queue.
Mar 20, 2015 | HP Photosmart 5520 e-All-in-One -...
Why wont my printer let me print off my work
Generally speaking when I see this message I just hit OK and it goes ahead and prints and everything shows up without being cut off - I am in the ink business and my test page shows this message all the time but its not an issue if you press OK and part of ther page is cut off you eitherr need to expand your margins or make the content fit the page
Sep 15, 2014 | HP Photosmart 5520 e-All-in-One -...
Why won't Print centre ?
HI,
Go to printer page margin setting option and set it. Because if print related any issue first go to printer setting option and set every thing link page layout setting, page choose setting, small fount setting every thing you can do it.
Thanks,.
HP Printer Support
May 17, 2014 | HP Photosmart 5520 e-All-in-One Printer
Hp 5520 will not print from sdhc card
From what I can tell from the specs, the 5520 works with SD cards, 2GB and smaller. It won't work with higher-capacity SDHC cards.
Mar 15, 2013 | HP Hewlett-Packard - Photosmart 5520...
Bottom of letters in document not printing.
it is problem your printer page setup please set defalt or re install printer driver
thanks
xptareq
Jul 30, 2009 | HP Photosmart C4180 All-In-One InkJet...
When printing a greeting card the copy appears too low on page so one fourth of an inch is cut off on the bottom of the page.
On Printer press Menu button.
Scroll down to tools an press ok.
Scroll down to Align Printer and press ok.
The Printer will calibrate automatically.
May 11, 2009 | HP Photosmart 8250 InkJet Printer
Printer will occasionally print incomplete document
Sounds like an issue with the bottom margin and/or footer if you are using a footer. Check the page setup and reduce the bottom margin.
Jan 24, 2009 | HP Photosmart C6280 Printer
I cannot print from the top paper tray
You have to select the photo tray to print to it - the printer will always default to the main tray.
If you have windows;
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00994721&cc=us&lc=en&dlc=en&product=3204464
If you have mac 10.4 or older;
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00039596&cc=us&lc=en&dlc=en
Dec 08, 2008 | HP Photosmart C5280 Printer
Oct 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP Photosmart 5520 e-All-in-One Printer Logo
205 people viewed this question
Seeker5211
Seeker5211
