Question about Motorola Mobility RAZR V3
No buttons work...not even the volume and others along side
No buttons except for the red button work...not even the volume button and others along the outside of the phone...I am able to receive calls...just can't dial out..help!
I had the EXACT same problem this morning. After leaving the cingular store where the guy just wanted to sell me a new phone, I went home and took the phone apart - just took off the battery cover, battery, sim card and the rest of the back cover, reattached cover, put everything back together and everything works fine now! Try it - good luck! You need a T5 torx bit to remove the two screws holding on the back cover.
Posted on Aug 31, 2007
My iPhone SE stopped making sound when ringing, it only vibrates. I have checked all settings/side button, all correct.All other alerts-text, etc.-still work with sound alerts. Anyone know how to fix?
One thing to check is the ringer volume - by default you can change the ringer volume using the volume controls on the side of the phone even when the phone is locked - this often means that it can get pressed in your pocket to zero volume, which is very annoying. Try pressing the volume up button from the home screen while not playing any music and see if it goes up. You can set the volume in the settings and even tell the buttons to only change music volume, which is what I do.
Jan 24, 2017 | Apple iPhone Cell Phones
I can't switch from windows to android, only the windows startpage boots up, even when pressing the stop and volume + at the same time.
Try using volume down along with other combinations such as home button and power button together with vol up or down.the phone must be off to start with and you need to hold said buttons for up to ten seconds.
Jun 18, 2015 | Cell Phones
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
AGING
6EDEH
S123 K234 Y
100 000 0
Sep 14, 2009 | Aiwa TV-S2011 20"
Keyboard stopped working
Take it into a repair center. You won't be able to fix it by yourself. :(
Apr 18, 2009 | LG RUMOR Cellular Phone
Washed my phone
your lucky the phone turns on - it is water damaged - if you want to fix it try to buy a broken one from ebay to get the parts.
Jan 19, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Buttons not responding.
you need a new keyboard assembly
Aug 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
