My 2.5ton mini tracked Pel Job digger just will not start. After ignition and the relays click in for the fuel pump and the pre-ignition she turns over but just will not fire up. Previously she was always a good starter and I never needed EasyStart products. I have replaced the Stop solenoid still nothing. As a last resort I put on a new battery, sprayed EasyStart into the air intake and turned her over - nothing. I am now at the end of my experience, anyone can help me I would be overjoyed. Thanbks barry
3 Suggested Answers
premtech
  • 934 Answers
SOURCE: Set won't turn on, timer light flashing and relay clicking
Jetster,
From what your describing the convergence amps, one or both, have probably failed and opened in the convergence circuit. That unit takes two STK392-040 amps and the feed resistors to those amps should be tested as well for any change in value.
For a shop this is a routeen job, we see them every day. But for a layman to tackle it - it could be the repair from hell.
The STK392-040 is both heat and static sensitive, so your $19.95 radio shack special soldering gun could ruin them in a blink of an eye.
They're mounted on the board against a large aluminum heat sink on the signal side of the chassis with heat sink compound and they're a multi-pin IC so they're not that easy to take apart and put in. Lining up all the pins to drop exactly where they're suppose to is a trickey task even for a technician, but then we have a few tricks that experience has taught well...
Call around and ask the shops what they charge for changing-out the convergence amps and testing the feed resistors in that circuit.. I would suggest taking the unit to them and save whatever they charge for a pickup and delivery.
Hope this helps!
Bill
Posted on Nov 11, 2007
simontricket
  • 235 Answers
SOURCE: how do i replace a track seal in my mini digger.
Slack off the track adjuster valve, spin the track off and pull out the idler assy. The seal is on the end of the chrome  piston just pull it out .
Posted on Dec 31, 2009
Pel job digger very difficult to start after fuel has run low
check fuel filter shake and dump out contents to see whats been going threw it, all lines for seepage get pump tester from auto parts store on loan OR Master Fuel Injection Pressure Test Kit
Nov 21, 2017 | Cars & Trucks
Pel job mini digger slew doesnt work but cab can be turned by hand
check for broken drive key /shear pin in the slew drive shaft
Aug 18, 2014 | Garden
Mercedes 300e 1989. Pre ignition when I turn the key off and still wont start. any help
if starter turns and engine will not ignite remember it is fuel, electrical or mechanical check the fuel pump relay then fuel pumps the relays do fail after 20 years the pumps rarly fail.
Did you change the fuel filter?
if starter does not turrn start checking
Fuses
Relays
Starter
Switch
electrical gremlins are challenging but if you are systematic and have a wiring digrahm you will find the problem
Jan 07, 2014 | Cars & Trucks
WHAT OIL DO I PUT IN A MITSUBISHI L3E ENGINE FOR PEL-JOB 1.5TON MINI DIGGER?
I have a similar engine in my mini excavator. I would recommend Rotella 15W40.. Good Luck
Aug 18, 2011 | Mitsubishi Lancer Cars & Trucks
Fuse and relay for the fuel pump
The fuel-pump relay unit is responsible for turning the fuel pump on when it detects the engine is running. When the ignition signal stops, the fuel-pump relay switches the pump off. Problems with the ignition and starting the vehicle often can be traced to the condition of the fuel-pump relay.
Description
  • The fuel-pump relay is a small unit, typically enclosed in a plastic case. The unit contains several sprockets on one side that are clipped onto the ignition system. The fuel-pump relay is engaged only during the start cycle. If it is faulty, it can take longer to start your vehicle.
  • Location
  • Most fuel-pump relay units are located under the dashboard near the steering column. In some cases, the unit is located in the area where the steering column is mounted or near the engine's firewall. The end of the fuel pump relay is typically located near the center of the floorboard, under the carpet in the front section of the passenger's or driver's side footwell.
  • Considerations
  • In addition to difficulty in starting the vehicle, symptoms of a poorly functioning fuel-pump relay include the following: the car dies then starts a few minutes later; the fuel pump makes a strange noise (humming or clicking loudly) for longer than five to 10 seconds after starting; or the engine won't start after you have engaged the fuel-pump switch.
  • Troubleshooting
  • When your car does not start properly, you can conduct a fuel-injection relay test. Two relays are located inside the fuel-injection system; one of them is responsible for turning the ignition on without turning over the engine, and the other is responsible for turning on when the engine turns.
    You can check to see if the first relay is working by touching it while turning the ignition on and off. You should feel a "click" every time you switch the ignition. If the fuel-pump relay is not working, you can "jump" the unit with a small lead jumper cable. You will need to access the fuse panel and insert the cable into the relay unit; the unit will run as long as the wire is inside the relay and can help start your car.
  • Jan 15, 2011 | Chevrolet Lumina Cars & Trucks
    Any idea how to top up hydraulic fluid in old mini digger pel job eb10
    Fill it where the hydraulic filter is in the tank .
    Nov 15, 2009 | Garden
    How do i replace a track seal in my mini digger please. its a volvo pel job EB 150 1998 type 261 with rubber tracks. Thanks Dave Good
    Sep 26, 2009 | Garden
    Both fuel pump relays run hot. I have replaced both of them. The truck started and ran for about 30 minutes then quit. I replaced the relays and it ran for a few minutes and quit again.
    You could have a bad fuel pump relay switch. The fuel pumpmag-glass_10x10.gif relay switch gets the fuel pump running in the vehicle during the start cycle. The terms fuel pump relay and fuel pump relay switch are used interchangeably. The fuel pump relay begins its job when the automobile operator turns to the ignition on, but before the motor is actually running. At that point, the fuel pump relay in some cars sends a signal to the ignition switch, which in turn sends a signal to the fuel pump to turn on. Others fuel pump relays have actual circuitry inside of them that receive the ignition signal and directly signal the fuel pump to engage.
    Have a great day!
    Sep 05, 2009 | Ford F-350 Cars & Trucks
    JCB 801.4 mini digger - no control of digger arm
    We have a similar problem on a Mitsubishi MM55SR.
    We developed a new control set-up
    Mar 17, 2009 | Garden
    Televison & Video Logo
    46 people viewed this question
    Top Televison & Video Experts
