Question about Hotpoint Dryers
Loud banging noise whilst drum is turning to dry
    New Friend:
  • 108 Answers
Hi put you hand in drum at the top at the back get someone to lean on top of dryer see if you can push drum upwards if so you need to change rear bearing if you do there is a cover in centre of the back held by two screws you will see a pin going through the shaft pull it out take bearing out some have a skrew holding it in to put new one in take lid off so you can pull drum up to push new one in place put pin and cover back its quite easy hope this helps
Posted on Feb 14, 2014
TheMobilian
  • 8220 Answers
SOURCE: dryer makes a loud noise when drum turns
loose blower wheel
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 15, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
SOURCE: Dryer has a banging noise
It Is fixable.All you need to is try to balance the load or a perfect concrete flat surface for the machine.
If the problem still persists, then during the previous vibrations, the shocks or the drum bearings might have been damaged, you might have well replace them to avoid further problems.good luck.and please post your comments.
Posted on Apr 11, 2009
taran_2005
  • 10515 Answers
SOURCE: DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
Posted on May 28, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Neptune Dryer makes loud noise while drying.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ergfgfjk
Posted on Sep 29, 2010
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Beko 510w
the beko washer sometimes the concrete balance blocks come loose and cause a banging noise unplug and take the top off check the concrete block on the top off the outer drum to see if it moves about tighten it up if loose then check the one down the front to see if louse
Sep 20, 2012 | Washing Machines
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Banging Noise in Kenmore Dryer
There are two rollers that hold the drum in place. I'm betting that one of those rollers have broken or fallen off. It's not a very easy fix since you'll have to take the dryer completely apart to fix it. Good luck!
May 25, 2009 | Dryers
Apr 11, 2009 | Whirlpool Dryers
Loud noise
it may have a loose drum you need to call some one to have look at it and don't try and fix it on your own because it won't work
Apr 26, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
