Question about Konica Minolta bizhub Office Equipment & Supplies
Can't locate the fuse on the c550 transfer belt.
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
I BELEAVE , ON THE DRIVE SIDE FRONT OF THE COPIER(WHEN ITS IN THE COPIER ITS ABOVE THE BLACK IU),JUST AS YOU SLIDE IT OUT, YOU WELL SEE TWO SMALL CONNTACTS
ITS BEHIND THEM, IF NOT ITS SAME PLACE BUT ON THE BACK SIDE
Posted on Aug 30, 2013
How to change image transfer belt unit on konika minolta bizhub c550
Transfer belts for the C550 series models are normally replaced by technicians. If you order the belt to install yourself, you turn off main power, open right side cover, locate guide plate under current belt, loosen thumb screw and remove plate, remove 2 screws securing the belt locks, remove front cable support on right side cover to lower cover, then pull belt out right side of machine. Install new belt in reverse order.
I would recommend a trained technician as the belts can become easily damaged.
Jul 18, 2017 | Konica Minolta bizhub Office Equipment &...
How to clean belt sensar in Konica Minolta c550
Remove the transfer belt. Then you will see two sensors located just below the end of the transfer belt closes to you ON the machine not the belt. there is cover you can gently slide it back and with a dry wag or gentle bush clean them you have to place you finger on the metal slide to slide to uncover them. pull slide to the front of the machine
Jun 05, 2017 | Konica Minolta Office Equipment & Supplies
How can I resolve error code C-2451
Release new transfer belt unit
• A new installation is not detected when a new transfer cleaner unit (image transfer belt unit) is installed. Remedy 1 Reinstall unit. 2 Check there is a short circuit in the fuse of the transfer belt unit. 3 Check the PRCB connector for proper connection and correct as necessary. 4 Change PRCB
Feb 02, 2015 | Konica Minolta Bizhub C550
How to fix error code c-3725
c-3725 -> Fusing abnormal high temperature detection. To get rid of this code, you have to follow the below procedure:
1. Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed;
2. keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below.
3. Restart it normally and it should work.
If the error is still there, you might need to replace the fusing unit. If you need anything else, just drop us an email at office@bizhubreset.com also, visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 14, 2014 | Konica Minolta Bizhub C550
Erreur P21 konica C650
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
Jun 08, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
Transfer Belt
It will definitely cause problems in the long run
Oct 29, 2013 | Konica Minolta Bizhub C550
Imaging unit
konica minolta bizhub c654e in display error c9401
no Utility/Counter key. howcreset I resolve lamp already change
23 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
