Question about Mitsubishi Televison & Video
Wd60737 audio present but picture black - Mitsubishi Televison & Video
    Top Expert:
  • Mitsubishi Master
  • 12,223 Answers
Follow this recomendation and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a Mitsubishi projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Posted on Jul 31, 2013
Location of the reset button on a wd60737
If the TV does not turn on or off, does not respond to the remote
control or control-panel buttons, or has audio but no video,
Press and hold the POWER button on the control panel for ten seconds.
The TV will turn off. Power on the TV and the green LED will flash
quickly for about one minute. The changes you made most recently,
before using SYSTEM RESET, maybe lost
Jan 18, 2017 | The Computers & Internet
Lg 50ga6400 tv has sound but no picture?
Please read the suggestions here:
The Led driver is not working no backlight This is an LG 50LA6200 Is the...
Feb 06, 2015 | LG Televison & Video
Wd60737 mitsubishi 60"
how long has it been since you replaced the Lamp in the unit
Oct 20, 2014 | Mitsubishi Televison & Video
Watching tv and after a thunder storm the screen
You haven't mentioned about whether there is picture or not. If picture too is absent, the fault is with its main power regulator board. If picture is present; only the audio is absent, the fault is with it audio output board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 16, 2014 | Televison & Video
My mitsubishi wd60737 has black 2 inch stripe
Try pressing along the edge of the frame surrounding the LCD. Look for a disturbance in the "black line". If that shows up, you have lost the bond from the electronics to the LCD. Try using a piece of inner tube between the plastic frame and the chassis where you pressed to hold the connection together.
Sep 18, 2014 | Televison & Video
Black Screen
If audio is present, the picture should also be there. If not, check the video output section circuit for fault. Check all the solder terminals for any loose soldering to this board. Audio output board can be located at the neck of the picture tube, will directly plugged on to its back. Re-solder all the suspected solder terminals; by applying a little more solder.
google.com/+GopakumarGopalan
Nov 07, 2013 | Ktv Televison & Video
Picture tube for 60 in' mitsubishi it shows only a black screen but you can still hear it
ts will go into shutdown when a vertical issue is present but the audio will still continue to operate normally.
Apr 02, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi wd60737. It will turn on. Remote does work. Sound does work. But, the video won't show. It just stays black. There is a solid red light when it is off. Tried to reset it and it still did the...
make sure u set ur output to AV u will find this on ur remote control or on front of ur tv set
in regards ur tv will not show a picture since ur last adjustment try to go to menu and follow instruction how to set the tv back to factory setting......this may give u ur picture back......if not call mitsubishi service centre and tell them about ur problem u have......i am sure they will help u
Nov 28, 2009 | Mitsubishi WD-60737 60 in. HDTV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
