Question about Craftsman Air Tools & Compressors
Only one stage of motor works sounds like a humming noise.
3 Suggested Answers
natengel
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
TX_AC_Man
  • 107 Answers
SOURCE: I have a split system
Trane has issues with loudness of their 2 stage system. Not saying its normal just saying its common. If you notice cooling ok in both stages then it can be narrowed down to refrigeration flow is noisy or a solenoid valve is loud.
Posted on Aug 21, 2010
The paddle on my kitchenaid won't turn. It just makes a humming noise. Any suggestions?
Is the humming noise the sound of the motor straining to turn without moving (it won't last very long like that) or the sound of the motor turning but not operating the paddle?
Dec 21, 2014 | KitchenAid Food Mixers
Tv works but no sound
Hello Jjwpod hi, to find where the trouble is, you need to place ear near speakers, you should hear a humming sound, adjust the volume up or down, the humming sound also goes up or down, this means your amplifier is working, no hum means trouble in amplifier.
summary:
No hum: trouble in amplifier, speaker connection.
Humming, but no audio: problem before amplification, most likely the Sound IF stage.
Sep 16, 2010 | RCA F27615 27" TV
I have a split system trane I16i 5 ton making a loud humming noise when it is in the first stage once it kicks into 2 stage it sounds ok
Aug 20, 2010 | Heating & Cooling
Garbage disposle makes a humming noise when turned on. InSinkErator Badger 5, 1/2 HP Garbage Disposal
Did you also hear any clattering sounds when it started? If so, it is rotating. If not then this hum is the motor in the lock rotor stage. Did you place garbage in it yet? Always run cool water in it when starting it.
May 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
Humming sound from the rear when I go over 60mph
from your symptoms of noise from rear ? i would say your suspision is correct it is probably one of hub bearings in the early stage of wear/burning out front wheels chocked raise each rear wheel in turn and with park brake off check for undue movement /rock in wheel/s and any noise when you spin ? if oone shows to be suspect ? advise you replace both sides ? this is not too expensive a repair and can be diy if you have tools and confidence? bearings come as a kit for each wheel/hub if you have time you will save $$$$$ in garage cost? hope this helps/inspires you best wishes from uk
Oct 30, 2008 | Hyundai Motor 2002 Sonata
Air Tools & Compressors Logo
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
